AFR Heads Question
Old September 16th, 2007, 08:25 PM   #1
javier351lx is on a distinguished road
AFR Heads Question
I have a question on the AFR Heads and they are stud mounted my question is i have a set of roller rockers that are for pedestal mount and i was wondering if i take of the stud mount braket would my pedestal mount rockers fit?
Old September 16th, 2007, 08:51 PM   #2
1987 ford mustang gt
well see when shes done
DO YOU ALREADY HAVE THE HEADS,BUY A SET OF ROCKER ARMS THAT ARE FOR STUD MOUNT
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old September 16th, 2007, 09:01 PM   #3
Rockers
Yeah i have the heads but if i buy some rockers that are stud mount i going to be gauging them all the time right! Or i may be wrong?
Old September 16th, 2007, 09:21 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You need stud mount rockers. No you will not have to adjust them all the time.
Old September 16th, 2007, 09:33 PM   #5
Rockers
How about these?
http://store.summitracing.com/partde...MS-M-6564-D351
Old September 16th, 2007, 09:39 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: Rockers
Originally Posted by javier351lx
How about these?
Sure if you insist on Ford parts. I think there are cheaper options.
Old September 16th, 2007, 09:40 PM   #7
Rockers
Like which ones?
Old September 16th, 2007, 09:43 PM   #8
Look at harland sharps.You dont like to shop around do you b/c it dont take much time at all to find rr that are cheaper than 300.
Old September 16th, 2007, 09:47 PM   #9
Harland
How about these but i want to go 1.7 not 1.6
http://store.summitracing.com/partde...3&autoview=sku
any suggestions
Old September 16th, 2007, 09:51 PM   #10
Dude are you even looking at stud size??????????
Old September 16th, 2007, 09:56 PM   #11
heres trick flow
http://store.summitracing.com/partde...1&autoview=sku
there 270.00 with nuts
and heres summit
http://store.summitracing.com/partde...B&autoview=sku
there 208.00 and they come with nuts
Old September 16th, 2007, 10:20 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: Harland
any suggestions
Why do you want 1.7?
Old September 16th, 2007, 10:25 PM   #13
Better right?
Old September 16th, 2007, 10:31 PM   #14
Re: 1.7
Better right?
what do you mean by better????????
Old September 16th, 2007, 10:33 PM   #15
dont know
I just said that?
Old September 16th, 2007, 10:33 PM   #16
by the way they increase valve lift and if im not mistaken your heads are only rated to .550 lift and you would be exceeding that with 1.7 roller rockers
Old September 16th, 2007, 10:33 PM   #17
Re: dont know
I just said that?
i mean what do you think is so much better about them
Old September 16th, 2007, 10:34 PM   #18
oh thanks
oh yeah thanks really ill go 1.6 rr
Old September 16th, 2007, 10:36 PM   #19
Dont really know?
Old September 16th, 2007, 10:36 PM   #20
your welcome just dont want you to get yourself into a bind.
Threads Similar to: AFR Heads Question
heads question sixpack 5.0 Mustangs 2 November 8th, 2007 08:22 PM
Question about heads. GTSilver 99-04 2 October 22nd, 2006 02:15 PM
Question about stage 3 heads and better cam Easy04_jm V6 Mustangs 0 October 19th, 2006 01:56 AM
Question (Cracked Heads) zeroarrn V6 Mustangs 5 October 14th, 2006 03:06 PM
Question About Heads White2000GT 99-04 7 September 28th, 2006 12:13 PM
