rough idle, bog @ 3500 RPM
Old September 16th, 2007, 09:02 PM   #1
Lmagee is on a distinguished road
Newbie here, new to the site and mustangs both, but no stranger to wrenching on stuff. Just picked up an 86 GT about a month ago. Car ran great for a few weeks and now all of a sudden one day driving down the road it died.
A little history on the car I got from the previous owner
recently installed 95 5.0 with 38k miles on it
mass air conversion with computer and mass air meter from an 89gt
BBK headers
march ram air
bbk h-pipe
3.73 gears
fuel pressure is @ a steady 40-45 psi through the RPM range
Has a new TPS, new distributor with new module and pickup
timing set @ 10 degrees
Has adaptive performance EGR eliminator and EGR block off plate
Anyways, after it died I pulled over to the side of the road and it would restart but you have to feather the gas to keep it going at first. After I got it going it seemed to run ok other than once I would get above around 3500 RPM it would start cutting out. Got it at work now and it will start and run but the idle surges alot and it idles rough. push the gas all the way to the floor and the car cuts out around 3500-4000 rpm let of the gas a little bit and it will rev on up. It is running very very rich
I pulled the codes, don't have them writen down right now, wiil update later, but from what I do remeber
these are KOEO
KOER came up with no codes
22-Map/bp sensor out of self test range
How does this play in now that the car is mass air converted? The map sensor is plugged in but no vacuum line hooked up?
This was a code that was stored in the memory also
Everthing else was just from the koeo test, from what i remember
There was one for secondary air injection
something about the fuel pump circuit in the ecm
Park/Neutral Position (PNP) switch circuit open
I will re-run the codes tommorow and update on exactly what the were
86 Gt
Mass Air
edelbrock intake
3.73 gears
bbk headers/ h-pipe flowmasters
March ram air
1.7rr
ect.....
Old September 16th, 2007, 09:11 PM   #2
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
Do you remember what happened when it died? How were you driving, did it die during a shift, did it crank right back up, etc?
Old September 16th, 2007, 10:24 PM   #3
1987 ford mustang gt
well see when shes done
i stole your car
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old September 16th, 2007, 10:52 PM   #4
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Originally Posted by jordan
i stole your car
You shouldnt have Jordan is that for me
*******Blushes agian because Jordan knows just what I want********
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old September 16th, 2007, 11:00 PM   #5
it is!!
Old September 16th, 2007, 11:01 PM   #6
I should have done a better job photo editing it.
Old September 16th, 2007, 11:05 PM   #7
Drick's Avatar
it is!!
UH HUH
FX4 Crew
Crew member #1
Old September 17th, 2007, 07:13 PM   #8
anyways, pulled the codes again today and got
22 map/barometric pressure
67 vehicle not in park or nuetral during key on
81 secondary air injection management "d" pr #2
95 fuel pump circuit open -PCM
The computer is a A9L
86 Gt
Mass Air
edelbrock intake
3.73 gears
March ram air
1.7rr
ect.....
Old September 17th, 2007, 10:36 PM   #9
Sounds like you need to find someone who knows what they're doing about these codes.
</ninja bump>
Old September 17th, 2007, 11:01 PM   #10
ryans88gt's Avatar
have you checked your timing? It sounds like your timing is stuck in a no advance mode. Check to make sure the little pin on the yellow wire off the distributor is making a good connection.
Other than that, check your fuel pressure, you might have a pump going bad which would go along with the open circuit EEC code.
Old September 18th, 2007, 08:46 PM   #11
did you read my first post? apparently not
also found out the open circuit EEC code has to do with the Maf conversion and it is nothing to worry about
86 Gt
Mass Air
edelbrock intake
3.73 gears
March ram air
1.7rr
ect.....
Old September 19th, 2007, 01:01 AM   #12
ryans88gt's Avatar
yeah, you said you timing is set at 10 degrees, but you didn't say whether the advance was working correctly!! If you set the base timing at 10 and plug the pin back in it should jump up to about 20 degrees advance.
Threads Similar to: rough idle, bog @ 3500 RPM
Rough Idle killagt46_t-top 99-04 5 April 20th, 2010 11:22 AM
rough idle :-\ help please! i know nothing about cars. tehdwarvenn 5.0 Mustangs 8 November 5th, 2007 10:01 PM
Intermittent Rough Idle and Stall Gallie 5.0 Mustangs 16 September 5th, 2007 11:52 PM
Rough Idle and Almost Dies After Warmed Up Gallie 5.0 Mustangs 10 April 12th, 2007 08:27 PM
Rough Idle And Acceleration When Engines Cool 97TunedMustang V6 Mustangs 7 November 11th, 2006 01:02 PM
