Discussing popping thought the intake tube?? in the 5.0 Mustangs Forum. Ok i just put a set of gt40p heads comp cam 512lift. I have crane ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Ok i just put a set of gt40p heads comp cam 512lift. I have crane arms pedistal mount rockre arms. I stater the car up and it is popping trought the intake tube/ The timing is at 15. Now do i have to shime the rocker arms if the are pedistal mount or i should not have to.
#2 | ||
From the land of the wolverines
1986 Mustang GT
Are you running premium fuel since the timing is so high and I wouldnt set the timing that high only about up to 14
yea timing is fine
#4 | |
I'm your huckleberry
Re: popping thought the intake tube??
I would personally get the timing down some and see what it does. |
i had it down and it still did the same.
#6 | |
sounds like a possible backfire or a firing order problem. Check what plug wires go where and recheck it all.
White99stang-
93 LX, H/C/I + Vortech |
firing order is right
i might be way off track here but if your talking about the shims for the roller rockers......you have to hand turn the engine till the pushrods are even at thier lowest point on one cylinder, hand tighten the stud....then torque the rockers to 18-20 lbs. within a 1/4 turn and a full turn...if they dont torque within that you need a shim until it does torque.....then repeat with all cylinders.....and sorry if im way off on what you were talking about
yea my buddy told me to torque them to 25lbs and it should not go no more then 1/2 turn till 1 full turn.
Threads Similar to: popping thought the intake tube??
| Granatelli cold air intake tube | zinc76 | For Sale | 7 | October 14th, 2007 01:52 PM |
| still popping through intake. Help!!!!!!!!!!!!! | nasty92LX | 5.0 Mustangs | 1 | September 19th, 2007 02:37 PM |
| water tube and niple for PI intake | caintcatchmyGT | 96-98 | 5 | September 18th, 2007 11:56 PM |
| CAI intake tube | ylw04girl | V6 Mustangs | 13 | July 19th, 2007 07:06 PM |
| red tube CAI (cold air intake) 1999 v6? | bullzi91 | V6 Mustangs | 10 | April 12th, 2007 11:52 PM |
