87 SPEED DENSITY CAM HELP, SOME ADVICE ON THIS SET UP
HELLO I AM HAVING TROUBLE WITH FINDING A CAM FOR MY SPEED DENSITY MUSTANG. I AM THINKING OF CONVERTING TO CARB SET UP. WILL THE SET UP BE GOOD OR NO. A EDELBROCK PERFORMER RPM INTAKE, A EDELBROCK 600 1406 CARB. A PRO COMP DISTRIBUTOR, AND FOR THE CAM I NEED TO KNOW WHICH IS BETTER THE E 303 OR THE B 303. PLEASE HELP ME. IM LOSING MY MIND, AS WELL AS TO MY BOSSES 2006 HEMI MAGNUM THANKS
ALSO I HAVE A MSD 6 IGNITION BOX, BBK SHORTIES, OR H PIPE, 5 SPEED, BLASTER 2 COIL, BLACK MAGIC FAN THANKS
48.47@ 12.58
don't convert to carb.
you would just be wasting gas. if anything convert to MAF. the abc Ford cams are over rated and old. they have a huge after market cam selection for your car. welcome to the forums.
can someone help me with a cam that i can retain the efi setup? all the cams say wont work with speed density. is there any out there i can use
1987 ford mustang gt
well see when shes done
yes but with speed density its not gonna be easy,convert to maf then you can do anything you want.
ps...any heads????
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
lunati voodoo has a cam that they say will work with SD
You could run a b-cam... I have one in my 88 SD and it runs hard.
E-cam lift .498/.498 duration @.50 220/220 B-cam lift .480/.480 duration @.50 224/224
04 GT SOLD 96 GT SOLD 03 COBRA STOLEN 89 LX SOLD 88 GT SLOW 06 F150 FX4 |
You can run any cam you want and any setup you want with speed density. The problem is, the computer will not correct for the new found airflow, so you you have to retune the fuel curve. Depending on how radical you get, you should be able to increase the fuel pressure to get it running strong. If that doesn't work you can have a custom chip burned for about the same price as converting to MAF.
The upside to converting to MAF or carb is that future modifications will not require a retune (most likely).
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Threads Similar to: 87 SPEED DENSITY CAM HELP, SOME ADVICE ON THIS SET UP
| Speed Density to MA conversion help | Project_Stang | 5.0 Mustangs | 3 | September 22nd, 2007 07:50 PM |
| Cai for Speed Density | Drick | 5.0 Mustangs | 16 | September 19th, 2007 10:20 AM |
| Speed Density VS MAF | Tr1gger | 5.0 Mustangs | 7 | April 17th, 2007 10:24 PM |
| Speed Density or MAF? | 8A_Honda | 5.0 Mustangs | 15 | February 6th, 2007 08:04 PM |
| Speed Density | Darrellx14 | 5.0 Mustangs | 4 | December 2nd, 2006 08:50 PM |
