Few questions b4 i shoot 100shot on my stock 302 carburated.
Basically what should do/adjust/buy before shooting 100shot on my 302ci?
i got a nos powershot kit. My set up is MSD 6A, Distributor, and coil, Dual 2 1/2 piping straight back to flowmasters, edelbrock performer intake mani, Holley 650cfm, sub frame connectors welded, 8.8 rear posi, 3.73 gear, holley electric inline fuel pump, adjustable fpr, stock everything else. 1. Should i get colder plugs? If so which ones? 2. What should i set my timing to? right now its at 14 advance. 3. Should i install a spearco water injection kit i was giving? If so run water or alcohol? All opinions, advice, and tips are appreciated. |
If you want to be safe, retard 2* per 50 horsepower added. However, I know on the EFI cars, the real racers won't even bother to take out timing unless it's more than 100. Wait for someone with some carb experience to back that up though.
1) autolight 24s gapped at 0.035-0.040
2)You should set you total timing at about 34 degrees. With a carb and no computer control, it doesn't really make sense to set your base timing. 3) NO |
What is the compression ratio? If it is 9.5:1 or less fill it up with 93 octane and leave the timing where its at. No need for colder plugs with a 100hp tune up. No water injection.
El Conquistador
DARRELL is that stock compression???
#6 | |
#7 | |
13.64@101mph
apparently you're mommy didnt teach you to not talk back to darrel..jpjp
#9 | ||
#10 | |
#11 | |
Threads Similar to: Few questions b4 i shoot 100shot on my stock 302 carburated.
| Stock 302 H.O Head questions | 93'_GT | 5.0 Mustangs | 41 | October 25th, 2007 03:55 PM |
| My First Shoot | 2000Mustang | Pictures | 32 | August 12th, 2007 05:24 PM |
| im carburated | skid6 | 5.0 Mustangs | 5 | July 2nd, 2007 01:04 PM |
| dont shoot the messenger! | CBSTANG | 99-04 | 4 | April 26th, 2007 10:44 PM |
| i have 2 stock questions | trebel14 | 96-98 | 10 | February 10th, 2007 08:40 AM |
