stroker?
i was planning on building my 302 into one mean street machine. i have thought about a stroker kit but not too sure which to go with. would the 306, 331, or the 347 do better with nitrous? i was also looking at a Trick Flow top end kit. would this combo work with the stroker?
87 GT T-Tops |
1987 ford mustang gt
well see when shes done
I would go with a 347 stroker kit with a 5.315 rods,they are located farther away from the oil ring and wrist pin.The trick flow top end kit should work pretty good and make some nice power.You can you nitrous on any of these motors if you use it right,i would do a 75 -100shot.
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
i was leaning toward the 347 with a 150 shot but i wasnt too sure how it would hold up
87 GT T-Tops |
WITH A 100 SHOT YOU WILL PROBABLY SEE 480 FLYWHEEL HP +OR MINUS 10-15.I would not exceed this limit b/c of the stock block.
true
87 GT T-Tops |
thats a good amount of power anyways,if your wanting more than that go with a 351w stroker.therye nit much more to build than a 302
13.64@101mph
yeah thats what im thinking bout this winter..trick flow top end ontop of a 347 stroker kit..but i want more like 400hp to the crank N/A maybe a little more..how else could i do that..or a dif set up..but i want to stay w/ 302 block..
I tthink turbo lx had a 347 stroker with the trick flow kit that made 410 to the flywheel.like i said it could be a littl more than 380 just an estimate it prolly is more like 400 +
13.64@101mph
yeah 400 to the flywheels great for me...i drive mine back and forth the high school every day..i dont need to make the 1/4 mile trip in 8 or 9 seconds..
and that would be roughly 375rwhp w/ my 5spd..not bad for daily car to school..
thats exactly what im doin high school daily driver with a about 380 maybe more at the wheels
13.64@101mph
hey jordan how old are you?? arent you like 25...still in high school...damn..
just playing...yeah well i want and need to be ontop..family tradition to have fastest car at school..but luckily my only competition is an 67 firebird w/ a basic modded 350..87 LX w/ exhuast, 86 GT w/ cowl hood..and an 91 LX w/ 306 w/ 240hp..so im pretty sure im ontop as is..but w/ the 347 stroker...they all can just watch from a distance..no touch..
Im 4 months away from being 16,theres no competition at my high school unless you consider hondas competition.
13.64@101mph
dude if i considered them competition..i'd have to hand you the keys to my mustang..bend over..and tell you where to put them..
hondas are mso's competition
Big timin' in a small town
306 is just a 302 boared 30 over isnt it I would go with a 331 I heard that the 347 is for more of the track and is not as streetable as the 331. That is why I am leaning toward the 331.
Jordan convince me why I should go with a 347 instead I know you now what you talking about buddy because im open to suggestions
A 347 has a bad name b/c the ones with the 5.4 inch rod tend to burn oil after a while b/c where the wrist pin is located near the oil ring,now the ones with a 5.315 rod>>>the wrist pins are moved out of the oil ring.347's have a bad rep and theres nothing wrong with the 347 for streetability,its the same thing as a 331(it just displaces more cubes),people just tend to say its not as street worthy.
Well actually that doesmake sense mabey I will look into building a 347 instead more hp
#18 | |
the only thing different you have to do with a 347 is notch the cylinder walls .065 b/c of the stroke of the crank but that might cost 50 bux
13.64@101mph
yeah but you can blame the problems on 16 more cubes..its that parts in the rotating assembly..those ppl need to buy better parts..not there grandparents crown vic parts..
Threads Similar to: stroker?
| Stroker Kit 101 | scxc15 | V6 Mustangs | 5 | November 4th, 2007 12:46 PM |
| To Stroker or Not to Stroker? That is the Question! | 87StangLX | General Tech | 13 | October 20th, 2007 10:46 AM |
| 347 stroker | mustang_s | 96-98 | 2 | August 7th, 2007 10:57 AM |
| 347 stroker | 2007calispecial | 5.0 Mustangs | 8 | July 31st, 2007 07:55 PM |
| 331 stroker | ballzout | 5.0 Mustangs | 8 | July 20th, 2007 04:59 PM |
