Discussing 1988 5.0 rear end swap in the 5.0 Mustangs Forum. Project: 1988 rear end and front axle swap Anyone know if it's possible to ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Anyone know if it's possible to swap a 96 GT rear end and front axles with the ones currently under my 88? My driver's side axle has the wobble syndrome. I think everything will fit just figured I would swap to 5 lug and disc brakes at the same time. Also if anyone knows the stock ratio on a 96 GT let me know. Is a 96 GT pos trac? |
91 Sonic Blue Goodness
19.83 @ 12mph
welcome to the forums.
I believe that the Axles are a bit long to fix in your car. I would look for axles out of a 5-lug fox body to insure proper fit. I believe the stock ratio is either a 2:73 or a 3:23 and it has a T-lock. |
1987 ford mustang gt
well see when shes done
just buy a 5 lug swap with rear drums.
I want to get rid of rear drums or I would just get another axle and shim it up. What years did they make 5 lug on fox bodies? Also did any of them have disk or only the cobras? Thanks for the welcome and the quick response. R U thinking the front or rear axles are going to be to long? Trying to find another way to swap to 4 wheel disk 5 lug and keep post trac since the new kits are so expensive. Will probably go with 3:73 gears being this will be drove on the street as well.
they did not have 5 lugs on the foxes they were all 4 lug
19.83 @ 12mph
i stand corrected.
just pulled this up: 1987 to 1993 Fox body 5.0 liter Mustangs can be easily upgraded to 5-lugs by simply installing 5-lug axles and drums from a Ranger or Bronco II in the rear and 5-lug brake rotors from a late 80's Lincoln Mark VII in the front. |
I thought all foxes were 4 lug but HMUSN had me thinking I missed something. Come on need some input have to get rid of the wobble syndrome it's very annoying at around 50+...Would rather just do the whole conversion instead of replacing one axle. Any insight on swapping to 5 lug with disc brakes...I was almost certain the 96 GT rear and front axles would fit but need to know for sure before I pick them up.
#8 | |
#9 | |
Ok so the only way to do the swap is get 2 drivers side ranger axles? The driver's side axles are they for the front or back converstion, do they have disc brakes? If so what about the rear?
86,97 mustang gt t tops
n/a
Do a little reserch mustangs dont have front axles. Here is a site that will awnser all your questions . I whent this rote and let me tell you it is no cheaper to do it right i spent $800 or $900 and then $1100 on wheels so $2000 on thaton alot of headackes but i used ranger areostar axles 95 mustang rotors and calipers and specail brackets sn 95 front spindles rotors calipers this takes it to 5 lug But dont forget to upgrade master cylinder and adjustable porportioning vale http://mjbobbitt.home.comcast.net/mustang/5lug.html
Anyone have a good link(s) or information on how to remove and replace the whole rear end? I found a pos trac rear with new 3:73's for $150
now just have to find out how to change them out
n/a
What year? if its 93 or older its just as simple as unbolting every thing and boting up new
1988 Hatchback 5.0, I looked the other day and it's looks as simple as unbolting and rebolting barring I get a tool to compress the springs, am I on the right track?
n/a
You dont need a tool for the springs jack up the car support the body jack up the axle unbolt shocks and brake line lower axle and springs will fall out with no problem.
Thanks!
Threads Similar to: 1988 5.0 rear end swap
| t-5 swap 1988 gt | stang5.0 | Drivetrain | 3 | April 13th, 2007 06:41 PM |
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 32 | April 8th, 2007 08:15 PM |
| 8.8 rear swap | Orangester | V6 Mustangs | 2 | January 23rd, 2007 08:00 PM |
| 8.8 rear end swap | scubasteve041186 | V6 Mustangs | 7 | December 18th, 2006 10:04 PM |
| 1988 4-cyl - 5.0 swap... need some hard to find info... | waz873 | 5.0 Mustangs | 2 | December 13th, 2006 06:20 AM |
