1988 Ford Mustang GT
8.372@82.8 1/8mile w/1.825 60'
EFI to Carb swap?
What do I need to do?Its an 88 302 what will I need?
Why go carb vs EFI? Just out of curiousity?
i just did this to my car....you will need a different regulator you can use the same pump but i went with an aereomotive A1000 and their carb bypass regulator and i upgraded all my fuel lines to braided steel feed and return you will need a carb and intake of course and you can use the same throttle cable but i switched and you can get one off a 83 carbed mustang take put your wiring harness and get mechanical oil and water temp guages a different distributor too and i think thats about it
Thanks I appreciate the help and im going carb because I dont feel like buying all the parts for a mass air swap so I got a great deal on a carb kit to go with my heads.Yea I kinnda figured all that you told me I have everything you just mentioned.All I need now is the machanical gauges.
Threads Similar to: EFI to Carb swap?
| EFI vs. Carb | gtstang87 | 5.0 Mustangs | 29 | August 31st, 2007 12:27 PM |
| V6 EFI vs Carb | quikstang2 | V6 Mustangs | 3 | August 17th, 2006 06:19 PM |
| How To Tell If Carb Is Too Big | GTXRacing | General Tech | 5 | May 11th, 2006 11:27 PM |
