NEED SUM HELP ASAP
Hey Im Installin BBK Chrome Shorty Equal Length Headers
I Just Finished Bolting The Drivers Side On And Put New Plugs And Gasket On There That Was A Bitch And A Half Couldnt Get The New Ones Underneath And Up So I Had 2 Go From Top And Down Do A Dislocated Finger And Alot Of Aggervation Its Not Bolted Down Thank God So Now For The Passenger Side This Looks Like Its Hella Hard Alot Of Fuel Pressure Lines, Intake, Tons Of Wires And Shit When I Started This Project I Had A Question 2 Begin With There Is Like An H- pipe On The Car And In The Middle Where The 2 Pieces Connect There Is Like A 1/4- 1/2 inch thick tube that is connected to the part that it connects and runs all the way up into the engine sumwhere just wondering what this is? also does any one kno if i start taking all the lines/wires/intake off the top is there enough clearance to take the old manifold out and drop the new headers in LET ME KNO WHAT I SHOULD DO KINDA STUMPED give me up help thanks alot everyone PaT #06 |
48.47@ 12.58
It is called an exhaust flange or exhaust gasket.
not sure on your second question.. maybe someone that has installed headers on a v6 might help. and go fix your finger before you lose it. a dislocation on the finger is no joke because you can pinch nerves and it's already one of the weakest circulation points of the body.
the 1/4 inch pipe is your smog pump crap and you might have to lift your motor up a little to get them in
the smog tube comes off really easy....so i think...took me 10 min. to get the whole thing off, it should just slide out of your exaust
sounds like the smog to me too...get rid of it. Plug the holes, and run a shorter belt...
hey
yea i think its the smog also does it unplug from the engine side half cuz its like welded on to the h-pipe do i even need the smog pump on my car? if worst comes to worse what happens if i saw the pipe close 2 where it connects to my h-pipe and maybe weld it later cuz that pipe is holding me up from havin my h-pipe drop down does anyone kno if it is still possible 2 get the old and new headers in from the bottom instead of the top or is the top easier but there is so much shit to take off and unplug thanks PaT #06 |
alot of people take the smog crap off and crimp the hose that goes to your exhaust ....you dont need it i took mine off its just extra space taken up
update!!!
well i unbolted the old passenger side header then disconnected cold air intake and cum smog shit slid the header out from the top came out nicely and the new header went in nicely also when i was taking the stock header off there was a steel/aluminum tube that had nuts on the top and bottom then was connected to the stock manifold and run up to behind the elbow of my trick flow intake not 2 sure what this is is this the EGR? do i need this ? on the new headers it dosent have a spot 2 hook up so j/w if i can take it off and put a new closeoff nut on it ? let me kno cuz i wanna fire her up by 5 thanks alot PaT #06 |
does it go through the fire wall? if so this is your heater hoses and if you want heat then you want to keep them if not take em out
hey
no it doesnt go thru the firewall it goes to the back of the intake elbow right after the throttle body there is 2 bolts that connects it to the back of the elbow and than ran down and connected to the old header the pipe cracked when i tryed to loosein the nut so there is a hole right now why can this be and is it okay 2 run with it like this thanks alot PaT #06 |
UPDATE HELP !!!!!!
hey
well i finished boltin everything up like 1 small leak but not 2 worried about it ill tighin up everything later i checked over everything and im sure i plugged everything in i started it up and everything idled great took it for a spin with my buddy and the throttle response sucked ass it was laggin alot and then after like 5 min through my check engine light im prettry sure its the EGR i did sum research on it and im def and HOPEIN that thats the reason why the accelaration was god awful well im going 2 go to the local hi-pre shop and get the EGR delete will this solve my problem does anyone have a site that shows me everything smog related that i can get rid of ? let me kno ASAP thanks alot heres sum pics ![]() ![]() ![]() ![]() thanks alot PaT #06 PaT #06 |
that hose and clamp in the second pic is your smog shit////////take it off and run a shorter belt....it helps
hey
there is no belt on those pics thats the pic where the egr connects to the back on the intake elbow im machinin my own egr delete block off for that im going 2 leave that part unplugged that pluged into that does anyone kno if thats the reason why my car feels like a HONDA CIVIC i had my car runnin pretty quick with the new gear and nitrous and now i thought that addin headers would get me sum more pop turns out 2 be a pain in my ass the only mods i did when installin the headers were puttin in autolite 24 plugs gapped to 0.040 everything seems 2 be plugged in correctly the car feels like its missin sumthin alot of power takin away i used 2 be able 2 spin thru 1-3 and now i can bearly spin 1st whats my prob NEED HELP ASAP thanks again PaT #06 |
i know i mean run a shorter BELT the only belt.....take the smog pump itself off and get a shorter serpentine belt, it reduces drag...and i hope you tightened that header bolt the rest of the way, as for the power.....what octane gas are you running,
hey
im running 93 octane the only smog thing that i took off was the EGR part that connects to the back of the intake elbow im makin a block off plate hopefully that will give me the response back do i have 2 run a shorter belt cuz i dont kno what 2 take off and i wanna leave it there for right now and get this other problem fixed Come on guys i need sum help thanks PaT #06 |
the reason he said get a smaller belt is only if you took your smog pump off if you didnt then you dont need to do anything
and if you dont want to take the shit off.....you can still measure your belt pattern just ignore the smog pump, and run the belt straight form the crank to the alt. or waterpump to alt, like mine was im asuming your is the same????? and you may have to get underive pulleys to get the belt to clear, if you havent already
does
anyone have a site or pics on all the smog/egr shit that i can take off im also gettin rid of all the ac components let me kno what i can get rid of tryin 2 free up sum space and make my engine look cleaner with eveythin gone all this stuff is useless 2 me no 1 needs AC with a mustang let me kno bout all the smog info thanks alot i fixed the car problem and made a billet egr deleate plate thanks 4 the help PaT #06 |
to get the smog off, take the bracket that holds the pump off unless its holding somethin else....then take the tubes and pipes that are connected to the pump, just follow them wherever the go until youve taken it all off, when its all gone just cover up or plug the remaining holes until till you can weld them or something.....there should only be one hole to plug, the one in you exaust h or x pipe wil be fine open
Threads Similar to: NEED SUM HELP ASAP
| NEED HELP ASAP!! | 92stang0802 | 2.3 Mustangs | 5 | October 30th, 2007 10:04 PM |
| NEED HELP ASAP!!! | Basics | V6 Mustangs | 19 | October 18th, 2007 10:33 PM |
| I need help with my fan ASAP..... | 92stang0802 | 2.3 Mustangs | 20 | September 4th, 2007 12:42 PM |
| help asap please | WeCircleTheProblem | V6 Mustangs | 14 | August 16th, 2007 06:21 PM |
| NEED HELP ASAP!! | VetteC5RFrEak | 5.0 Mustangs | 0 | August 3rd, 2006 02:01 AM |
