Is MAF worth it?
Old September 25th, 2007, 06:28 PM   #1
dan's93LX is on a distinguished road
Is MAF worth it?
I have a 93 LX with a 5.0 out of an 88 T'bird. I am considering putting a set of 351 heads on it, and I was wondering if they would be a direct bolt on or if some modification was required. Another thing. the engine runs on the speed density system and I was wondering if there was an alternative to converting it over to MAF.
Old September 25th, 2007, 06:47 PM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
MAF will make a difference but only if you plan on doing heads intake and cam like swaps you could problly put those 351 heads on with no problems you shouldnt have to swap to MAF
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old September 25th, 2007, 07:24 PM   #3
Speedstang302's Avatar
13.64@101mph
but if he doesnt do the valvetrain stuff that he will need to switch to maf...cuz sd doesnt take well to any mods rlly..
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old September 26th, 2007, 10:10 PM   #4
408gt91's Avatar
408gt91 is on a distinguished road
if you put more air through the motor the s/d computer cannot adjust the fuel to make up for the air increase it has no way of measuring,thats what the maf does. it tells the computer how much air its taking in and in turn the computer will adjust the a/f ratio.i would suggest doing the mass air swap before any other mods.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old September 26th, 2007, 11:30 PM   #5
13.64@101mph
Threads Similar to: Is MAF worth it?
Worth it?? Kenzo V6 Mustangs 9 September 2nd, 2007 04:12 PM
worth it?? GTsetGO Classic Mustangs 6 July 29th, 2007 08:04 AM
Is this worth it? gtg8920 V6 Mustangs 7 March 24th, 2007 02:11 PM
CAI: Really worth it? HessiaN257 99-04 20 March 18th, 2007 11:22 PM
Is it worth it? 68 dlxcoupe 96-98 10 March 14th, 2007 02:54 PM
