What Is This Pulley?
Im looking at the front of the block and I'm curious what the pulley underneath the alternator runs, It wasnt connected on the belt so idk what it is. If anyone has a diagram for the pulley/serpentine system for an 89 5.0 that would be awesome, thanks.
Should be the smog pump pulley, it's just been by-passed. Here's a diagram.
yep. smog pump
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
smog pump??? sounds like a waste of space to me....
#5 | |
Smog pump is a waste
"Those who forget the past are condemned to repeat it" Rev. Jim Jones |
Remove the smog pump or "Air Pump" as the little pic on your frame would say and get the belt size 855k6 85.5" 6 ribbed
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
I JUST GOT A SMOG PUPMP DELETE BUT I HAVE A GUY TO DO MY SMOG 4 ME
well shit this town aint big enuf for the both of us |
anyone know what size belt a 1995 gt would run if not using the smog pump??
1995 GT::Sold! Looking for another stang... |
Look at the manufactuer belt size for your car/truck, removing the smog pump normally would knock off about 7-10 inchs to be close.
Like mine which calls for a 77, I took the smog pump out and I had to get a 855k6
I'm sorry I got that all screwed...
Mine called for a 90 and I had to get an 855K6
If your smog pump was deleted/by-passed Chadderkdawg you might wanna see if they bloked off the pipes on the back of the heads and blocked off where it runs down to the collector or you might burn up some important shizit bro!
Drew why buy the delete kit for the smog pump when you can just by-pass it and use the money for the A/C delete kit!!!!!!! I just wrapped a piece of string around how the belt was suppost to go and marked it and brought it to the auto parts store and said "gimme a belt this long dude!"
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it! |
alright, so if i want to bypass my smog pump, will i have to take it off, or just dont put the new belt around it? I wont do this unless there are performance gains in it, but i dont need my smog pump with the no emissions, and i plan on getting an o/r x in a week or two.
From what i've been told there is no real performance gains and i would recommend deleting the cats along with the smog pump as the pump helps warm the cats up so they perform properly.Unless you are looking to lose like 20lbs i can say you most likely feel ant difference in power.Me, i feel anything that the crank pulley has to turn but the water pump and alternator need not be there (A/C,power steering included!).
It would almost be pointless to just by=pass the pump and not take it off because you'll have to plug the holes in the back of the heads,plug off the tubes that run down to the collector and cap the vacuum lines as well.Like i said ,if you aint a hardcore dragger or just like me an dont wanna lose even 1 pony to belt drag there is no benefits to smog pump delete! Good luck though
ok, i just put on my new underdrive pulleys, and i thought that since i was already in the area i would try to get a few more horses, but it sounds like it isnt worth it. Thanks for the answer though, i didnt really understand the smog pump, but this car will eventually be a drag, just not yet.
Threads Similar to: What Is This Pulley?
| 8 rib pulley | BrokePerformance | General Tech | 4 | April 3rd, 2008 06:35 PM |
| new pulley | chozen1 | 2005 - 2010 | 7 | August 8th, 2007 12:06 PM |
| ud pulley | miles miles | V6 Mustangs | 12 | May 21st, 2007 09:48 AM |
| ud pulley | mmvi | V6 Mustangs | 4 | May 2nd, 2007 12:35 PM |
| UD pulley is on | ByPopularDemand | V6 Mustangs | 8 | April 12th, 2007 04:19 PM |
