Discussing Removing non-working AC & Smog in the 5.0 Mustangs Forum. I figured since the AC doesn't work anyways I would just remove the dead ...
Old September 29th, 2007, 11:58 AM   #1
Project_Stang's Avatar
I figured since the AC doesn't work anyways I would just remove the dead weight but I need to know if I need to do anything special in order to make sure that I still have heat? Never done this before so any help is appreciated. Also removing the smog pump I take it just plug all the lines from the source? Also if anyone could provide the proper belt length needed once this is done it would be appreciated.
Old September 29th, 2007, 01:23 PM   #2
sniperrider's Avatar
for the smog.....take off all of the rubber hoses that were connected to the pump....take everything off except for the tube that is connected to the heads.....i still havent got around the cutting it so its just plugged....as far as the a/c goes just follow the shit back from the pump......you can leave two holes in the firewall on the passenger side inside the engine compartment.........belt size on my 90 is 68.5 but that is with underdrive pulleys.....you can just take off your belt now and run a string around the new path to measure it......
Old September 29th, 2007, 01:31 PM   #3
So removing all the AC stuff, lines, etc...will not affect my heat?
Old September 29th, 2007, 01:46 PM   #4
it shouldnt mine still works......you dont need a/c pump to run your heater......and if you want to make sure just after taking a part off test your heater if it works your good if not then you took sonething off that is supposed to stay on
Old September 29th, 2007, 04:45 PM   #5
Chicken Plucker
Drick's Avatar
2003 GT
You want to buy a power steering relocate kit that moves the P/S pump were the A/C used to be this is a usaual practice in a/c delete and you will want to runs a short belt for bypasing the smog just got to the parts store and keep trying different belts until one fits that the only way to find out
Military Crew
ADAA
Modular Mustangs are two damn confusing
Crew Member #1 Founder
Old September 29th, 2007, 09:35 PM   #6
Do I have to move the P/S pump? or can I just use a short belt and leave it where it is haven't looked at the belt routing to see if it's doable yet
Old September 29th, 2007, 09:41 PM   #7
Chicken Plucker
Drick's Avatar
2003 GT
you will move the p/s pump were the a/c compreser used to be Ford Racing makes a relocating kit
Military Crew
ADAA
Old September 29th, 2007, 09:45 PM   #8
So I take it this is a must if you get rid of your AC junk? Are all the P/S lines long enough?
Old September 29th, 2007, 09:48 PM   #9
Chicken Plucker
Drick's Avatar
2003 GT
I dont know if its a must but most everyone who does it does the relocate kit there is a few people in here that have done it
Military Crew
ADAA
Old September 29th, 2007, 11:13 PM   #10
Speedstang302's Avatar
1989 Mustang 5.0
dunno yet
i dont have A/C and i still have my P/S pump in stock location..and you can remove smog pump if you state requires you to pass emissions...ASP makes a rlly nice looking free spinning A/C delete bracket and an Smog Pump delete bracket..that adds looks and functionality..and you can use stock belt..
ASP A/C Delete:
http://www.latemodelrestoration.com/...0%201&comp=LRS
ASP Smog Delete:
they look the same...but both are for either delete..but bolt into stock location..i have A/C bracket..
new project..89 5.0 full restoration beginning..
Threads Similar to: Removing non-working AC & Smog
AC not working chuck&monika 2005+ 5 August 6th, 2007 02:33 PM
removing smog pump on 87GT marks87gt 5.0 Mustangs 1 April 20th, 2007 04:04 PM
removing the smog pump cali 5.0 5.0 Mustangs 1 April 19th, 2007 06:34 PM
WTB a working T-45 JRuckas Want to Buy 3 October 7th, 2005 08:32 PM
