Head bolt seeping antifreeze
Old September 29th, 2007, 03:37 PM   #1
demononwheels's Avatar
demononwheels is on a distinguished road
I just install a pair of new heads on my 1993 mustang. I'm sure I have the right head gaskets and the heads are torque to spec in the right sequence.
One bolt on the driver side is seeping antifreeze from under the nut. The nut is tight. This would be bolt number 10 (front bottom bolt) if your looking at a torque sequence for a GT-40X XTRA PERFORMANCE “TURBO-SWIRL” ALUMINUM CYLINDER HEADS instructions.
Any one ever had problems like this?
Old September 29th, 2007, 03:39 PM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
The head is probly cracked around the bolt
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old September 29th, 2007, 07:26 PM   #3
Maybe, but the machine shop ported, polished, and milled my heads and asked them to let me know if anything was wrong with them before they did the work. Installed by them too.
I'm just trying to figure something out before I call them Monday.
Old September 29th, 2007, 07:48 PM   #4
i would have them take a look at it...we cannot be sure without pics or anything.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old September 29th, 2007, 08:33 PM   #5
Drick's Avatar
yes have them look at it because if they did screw it up you dont want them to pin the damage on you I would drive it over there and make them take a look at it
FX4 Crew
Crew member #1
Old September 29th, 2007, 10:15 PM   #6
Speedstang302's Avatar
13.64@101mph
well also better hope you didnt accidentally torque that one bolt too hard and crack it yourself..
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old September 29th, 2007, 10:22 PM   #7
Drick's Avatar
Yeah that would be bad
FX4 Crew
Crew member #1
Old September 29th, 2007, 10:24 PM   #8
I guess I'll have to pull the head off. I carefully looked at the corner of the
head and from the outside, I see no cracks. I'll see what happens Monday.
Thanks guys
Old September 29th, 2007, 10:26 PM   #9
1987 ford mustang gt
well see when shes done
you need to ,let them pull the head off theirselves
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old September 29th, 2007, 10:56 PM   #10
Well,
There're a machine shop. I guess I would need to pull the motor back out
and take the motor to them.
Old September 29th, 2007, 10:58 PM   #11
just take the whole car down there they did the work!!And did you buy the heads through them??
Old September 29th, 2007, 11:01 PM   #12
They did the work as far as the rebuild on motor but I put the motor in the car. The heads I got from ford motorsport. I'll call them monday to see what they say.
Thanks
Old September 29th, 2007, 11:29 PM   #13
Drick's Avatar
That definitly what you need to do mabey if you couldnt drive it too so they cant say anything to you about it
FX4 Crew
Crew member #1
Old September 29th, 2007, 11:54 PM   #14
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
you need to check if the head bolt goes int o the water jacket some chevy motors do that and you have to use rtv on the threads of the head bolts. my dad owned a machine shop for more than 20years. now im not sure on the 302 i have yet to do the heads on my car
Old September 30th, 2007, 10:35 AM   #15
ujslost's Avatar
if you did machine work on the heads, ford motorsports aint gonna help ya any.
Old September 30th, 2007, 12:41 PM   #16
Yea, I knew ford wouldn't help cause of the head work. I just wasn't sure about the water jackets on my heads or block. I didn't know were they were located.
It looks like he did use some kind gray sealant. I'll try to take some pics to show ya'll what I'm talking about.
Thanks
Old September 30th, 2007, 01:29 PM   #17
ujslost's Avatar
hope he didnt port to much!
Old September 30th, 2007, 02:52 PM   #18
Here are some pics. Anti-frezze is dripping out from under the nut.
Old September 30th, 2007, 03:24 PM   #19
ujslost's Avatar
try taking that bolt back out and cover the threads in some RTV and reinstall and let it set for 24 hrs and retry.
Old September 30th, 2007, 03:30 PM   #20
I have a spare 302 that I just took apart. On the passener side, there is a water jacket that could possibly cause that front bolt to seep anti freeze.
Here are a few picks. One pick show the bolt hole with 1/8 inch hole on head gasket which allows a little bit of water to run though and the other pic shows light from my flashlight shinning though the 1/8 hole and visible though the head bolt hole.
I guess the machinest didn't apply enough sealant.
Threads Similar to: Head bolt seeping antifreeze
Head Bolt Headache Buttaz V6 Mustangs 14 August 2nd, 2007 08:06 AM
i6 Head Bolt Torque tnknepp Classic Mustangs 5 July 30th, 2007 08:21 PM
3.8L Head Bolt Torque Cosworth V6 Mustangs 6 April 23rd, 2007 03:05 PM
Debris in head bolt holes... lwhitetrash88l V6 Mustangs 5 April 12th, 2007 12:25 PM
Stubborn Head Bolt lwhitetrash88l V6 Mustangs 4 April 11th, 2007 11:49 AM
