help with a couple of questions
Old October 1st, 2007, 07:43 AM   #1
sixpack's Avatar
91 lx vert
sixpack is on a distinguished road
ok im needing some help with a few things and i know you guys know the answers ok my first problem is i have a 91 vert im building im putting a 347 stroker kit in it i have the block machine work done what i need to know is will a 28oz work in it or do i have to have a 50oz kit since thats what it was stock. im gonna buy a new harmonic balancer and flywheel anyways so i can go both ways another problem i have is motormounts does a vert have special motormounts or can i use any fox body mounts my old ones are wore out also are the shocks and struts special on a vert im wanting to use lakewood drag shocks and struts and eibach springs thanks for any help
Old October 1st, 2007, 01:45 PM   #2
408gt91's Avatar
408gt91 is on a distinguished road
Use stock vert mounts most guys use em,your stroker kit has to be balanced,i would get a 28oz flywheel and balancer then bring the kit with the flywheel and balancer to a machine shop to have balanced.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old October 1st, 2007, 02:13 PM   #3
ryans88gt's Avatar
If the kit is made for 50 OZ external balance you need 50 OZ flywheel and balancer. 28 OZ then 28 OZ.
If you are going to have it rotationally balanced, they can make 28 OZ work, but it is going to be expensive as it will take a few slugs of mallory heavy metal to get it to balance. Plus there is no advantage to using 28 over 50.
Old October 1st, 2007, 09:38 PM   #4
IcantDo55 is on a distinguished road
Zero balance it. Cost is a little higher but well worth it.
Vert mount lower the motor about 3/4"
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Threads Similar to: help with a couple of questions
Just A Couple Questions Youngin The Clubhouse 44 November 13th, 2007 03:11 AM
Couple Questions Youngin V6 Mustangs 12 October 8th, 2007 09:49 PM
couple questions MisterFast3 V6 Mustangs 23 September 18th, 2007 10:55 PM
A Couple Questions Vision.Pro V6 Mustangs 27 May 8th, 2007 10:34 AM
a couple questions trueballerisme 2005 - 2010 7 December 10th, 2006 04:39 AM
