Starter or Starter Relay
Old August 2nd, 2006, 08:48 AM   #1
cobralini is on a distinguished road
When I go to crank the car sometimes I only get a click. I have to turn the ignition 2 or three time before it actually cranks . could a bad battery do cause this too?
Old August 2nd, 2006, 08:59 AM   #2
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
Check the selenoid...But also make sure that the battery cable is tight and not lose on any of the connections...
Facebook
Google+
Old August 2nd, 2006, 11:36 AM   #3
dcraig8 is on a distinguished road
make sure your main engine ground is clean and tight also. i know that i tell this to alot of people, but you would be amazed at what a corroded or loose ground will do. you'll be changing parts left and right and nothing will seem to fix the problem....check it.
Old August 2nd, 2006, 11:47 AM   #4
I think I will get a wire brush and clean the ground areas really good , spray alittle WD-40 , then put everything back.
Would a bad battery do the same?
Old August 2nd, 2006, 06:49 PM   #5
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
It could...
Facebook
Google+
Old August 2nd, 2006, 08:49 PM   #6
stang fanatic's Avatar
stang fanatic is on a distinguished road
whats occured when it only clicks? has it always been after sitting overnight? after a short run to the corner store?
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 2nd, 2006, 11:15 PM   #7
Mostly after sitting over night. During the day it normally fires right up.
Old August 3rd, 2006, 07:34 PM   #8
sounds like a bad battery...during the day its getting a good charge...but sitting overnight draws down on it and lacks amperage
Threads Similar to: Starter or Starter Relay
starter help please??? lwhitetrash88l 5.0 Mustangs 4 November 8th, 2007 08:45 PM
starter HELP!!!!! dcrow 99-04 8 October 2nd, 2007 10:28 PM
starter notsoslow50 5.0 Mustangs 6 August 21st, 2007 11:47 AM
Need Help A.S.A.P! (Starter) sn-95aac 5.0 Mustangs 13 February 28th, 2007 09:32 PM
starter relay terribleonexx88 5.0 Mustangs 22 December 4th, 2006 05:11 PM
