Braided Fuel Lines
I know Russell sells braided fuel lines that go from the firewall to the fuel rails. Does anyone sell the braided lines that would replace the complete supply and return lines? I will be welding in some thru-floor subframe connectors and was thinking of upgrading the lines insttead of rebending the stock lines. What size do most people go with?
BTW- what is the second hard line that goes down the passenger pinch seam and has a rubber hose in the middle of it? Thanks. |
aereoquip i think sells it 20ft sections and are you carbed or fuely?i am carbed and i went with 10 feed and 8 return and 6 to the carbs ...and i think the hard line is the brake line ..almost posotive
#3 | |
1987 ford mustang gt
well see when shes done
nope the fuel lines are metal to
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
#5 | |
the steel lines are 5/16
#7 | |
yes that is the od on the supply line,i forgot about the return line
#9 | |
http://www.jegs.com/webapp/wcs/store...63398_-1_10019 or http://www.polyperformance.com/shop/...cat=434&page=1 What sizes are the push-type connectors on the fuel tank? 5/16 for the fuel supply? What about the return line? |
The return line I believe is 1/4", I know it is smaller than the feed line by 1/16", so if 5/16 is correct for the feed, 1/4 is correct for the return. Just go out to the car, take an adjustable wrench tighten it around the line and then measure the wrench opening...
If you are going to go to the trouble of running fuel lines, get a new pickup that has -8 or -10 fitting on it so you don't have to worry about getting the correct connectors to the restrictive stock pickup. Or just put a sump on the tank. i.e. http://www.carshopinc.com/product_in..._id/35103/4205
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#11 | |
well, if you are only going to run a 255 lph intake pump, don't bother upgrading your lines. The stock lines can support 450-500hp, about the same as the biggest intank pump.
Threads Similar to: Braided Fuel Lines
| Braided lines / Brake pads | Wado | 2005 - 2010 | 22 | October 11th, 2007 11:04 PM |
| Fuel lines | JBIGBOOTSY | 5.0 Mustangs | 2 | August 31st, 2007 07:10 PM |
| Fuel Lines | terribleonexx88 | 5.0 Mustangs | 3 | February 28th, 2007 10:58 PM |
| Do I Have To Swap The Fuel Lines? | OTreborO | General Tech | 1 | November 9th, 2006 08:31 PM |
| fuel lines | 2ToneFox | 5.0 Mustangs | 3 | August 7th, 2006 06:16 PM |
