1987 Mustang GT
Ford motorsport x 303 heads
are these heads any good ? Just asking because i might be able to buy them off a guy for a really good price. Should i bother?
1987 Mustang GT
anyone?
1990 Mustang gt
Bad Breath
They're not bad heads. They breath better than stock and are alot lighter. But buying new is not really worth it because they're not much cheaper than trickflow or afr which breath way better. Depending on the price though i might recommend them.
2002 gt 5-speed slow 1990 gt 5-speed junk |
13.64@101mph
yeah what price..cuz if its around $1000...just buy trick flow twisted wedge 2.02 heads...flow better and are like $300 more..and are new..
I have them. Not the best in the world but I am making decent power with them. Not worth it to me to swap them out with something else yet. As others have stated, depends on the price.
Ford rates their crate engine at 340 HP flywheel which is basically a production 5.0l with X303 heads, an E cam, and a GT40 intake.
13.64@101mph
also with roller rockers, and a bunch of other little stuff..
not a bad head, but if you have the extra couple hundred, then just get some twisted wedges.
1987 Mustang GT
for around 500.00 - 600.00 worth it ?
1990 Mustang gt
If they're in good shape I'd say go for it.
#10 | |
Re: Ford motorsport x 303 heads
1987 ford mustang gt
well see when shes done
thats what hes getting a set for
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
oh sorry, didnt read the first post...not a bad price...the lowest you will probably ever find on a set of used Trickflows is 800-900...In my opinion, go for it!
nope get cast iron RHS. other then there aluminum they are the best head going. and there only aobut 600 each i beleive.
http://www.fordracingparts.com/parts...tKeyField=2601
I have these heads as well, with 1.7's. Bought them used with not many miles on them. I havent put them on...should i sell and buy different ? I also have a Vortech V2-SQ with 8rib system. Will they work well with the s/c. Or should i just let them go and get something else.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
I run those heads with 10# boost. Again, not the best head but they will work. I am not looking for a full drag car or the lowest ET possible out of my car (I still have cats,air pump, EGR, working A/C etc) and I rev limit at 6K so I can not comment on the performance above that other then it is still pulling hard when I hit the rev limiter.
I have other things I want to do with the car before I think about better heads but it is on my list.
Threads Similar to: Ford motorsport x 303 heads
| Sean Hyland Motorsport | 00vabchgt | Vendors | 3 | April 9th, 2008 01:10 PM |
| Ford Motorsport Springs | gotboost562 | 5.0 Mustangs | 8 | October 21st, 2007 08:57 PM |
| ford racing cnc heads | garydahl | General Tech | 1 | July 30th, 2007 12:19 AM |
| Ford racing cnc heads | garydahl | Modular Mustangs | 1 | July 24th, 2007 02:47 PM |
| '88 Ford 302 w/ 03 Cobra ported heads | ztrane | 5.0 Mustangs | 17 | March 20th, 2007 11:12 PM |
