Big timin' in a small town
My dream 347 build
When I get the money for this. This is what I am going to build what do you think of this setup and what should I change
Boss 302 block from Ford Racing Trick flow top end kit F cam from Ford racing 30lb injectors ford racing roller lifters harland sharpe roller rockers 347 Scat rotating assembly MAF conversion and best of all Twin Turbo setup with exhaust waste gates
1987 ford mustang gt
well see when shes done
42 lb injectors,screw the cam,if you dont want a custom grind go with a stage 2 from trick flow.And i would call chp on the stroker kit
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
42lb thats not to big and yeah forgot i will problly go with custom cam this setup will be so bad ass does any one have an HP estimate I was gonna say around 550-600
how much boost and 42 should be perfet for you just depends on boost
shoot your gonna need like 60lb injectors with twin turbos ...get some like insane canton race heads and jesel valvetrain
13.64@101mph
i see jordan dreaming..but his 408 is a little more realistic...you want a twin turbo 347 stroker with about 600hp...well first off you'll need all new tranny, drivetrain, cant use any 302 block besides dart or world..twin turbo you'll need more than 42lbers..unless you plan to make it a drag car...
is the point of 600hp..450hp would be perfectly fine...and you get an A+ on the harland sharp roller rockers..been around the longest and still make the best..fcam isnt bad..but a comp, crane, lunati or custom would be the only practical cam to use on that..and another thing you going roller or solid lifter??
see i didnt know how much power he was gonna be making i thought more around 500 with low boost so i said 42
#8 | |
13.64@101mph
see i dont dream that far off..i just want my 347 stroker, tremec tranny, built rear end, clean stock look interior and clean drag racing looking body..thats it..not 8000hp and stripped and shit..i kinda want a notch right now though..i've seen a couple in mags i like alot..and there not 1 around for like 5-6 towns...i think theres 1 or 2 on ALL of cape cod..
when i build my 408 its gonna be in a full weight street car not stripped and sstock interior,and you just named what im doing with my car hopefully i can be able to get a tremec tranny.ive had my car for three years and never driven it
definately go with 60lb injectors.
sounds like a killer setup..... mine is at the tuners as we speak. hoping to have it back by thursday. I will let you know the results. I think 600 hp is doable. |
i hope you got a good job, or alot of time to save!
#13 | |
ha amen |
ive got alot of time to save
#15 | |
OH and im aware of that I will need new tranny and clutch and everything else so thats not in this only the motor setup
Threads Similar to: My dream 347 build
| A sons's bad dream.... | TurboLX | The Clubhouse | 17 | August 13th, 2007 12:43 PM |
| Dream Car? | Youngin | The Clubhouse | 40 | April 3rd, 2007 08:40 AM |
| found my dream car | Drgnracin72 | The Clubhouse | 17 | January 24th, 2007 01:54 AM |
| My Dream Car... | stang_babe | The Clubhouse | 39 | November 5th, 2006 08:36 PM |
| My dream 5.0 | banini | 5.0 Mustangs | 0 | September 17th, 2006 01:11 AM |
