timing issues
Old October 2nd, 2007, 07:56 PM   #1
acannoniii is on a distinguished road
timing issues
i have a 88 mustang gt that had some things done to it before i bought it. i was told it had a new larger cam put in it however i have set the base timing twice and after driving it a day or two it loses it's timing and starts missing and sputtering. once it warms up it hunts while idling between 500 and 900 rpms. i have replaced the temperature sensor, the act, intake manifold gaskets, air bypass soleinoid, fuel injectors, o2 sensors, adjusted tp sensor, and plugs. please if you have a suggestion i would love to it. thank you
Old October 3rd, 2007, 02:06 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
distributor gear look ok? timing chain or belt?
Old October 3rd, 2007, 06:07 PM   #3
distributer gear looked fine. i am going to look at the chain this weekend.
it has to be mechanical for the timing issue. i unplugged the chip at the distributer and it ran even worse than before. the surging i am going to check grounds and vacuum leaks again to be sure. it also has a napa remaned computer in it so i believe whoever had it sold it because of these problems he couldn't fix.
Threads Similar to: timing issues
timing issues sonicblue 5.0 Mustangs 2 October 7th, 2007 08:16 PM
New guy with issues. 01GT 99-04 9 May 25th, 2007 02:59 AM
OVERHEATING ISSUES SUPERCHARGED_GT-2005 2005 - 2010 1 March 24th, 2007 05:51 AM
Timing Issues 86yoass General Tech 4 July 14th, 2006 04:54 PM
93 5.0 with issues hrsepwr44 5.0 Mustangs 2 May 8th, 2006 11:36 PM
