efi or carb?
whats up names matt im kinda new to forums so bare with me.. anyway here go's..i have an 88 mustang gt..stock block gt40 aluminum heads.. trickflow upper n lower track heat intake..65mm throttle body..b303 cam. stock injectors...headers into dynomax race mufflers then dumps...t5..8.8 with posi 373's... my question is since the car has speed density.. and will not hold an idle at all!.. should i toss the efi and go old school carb or get the mass air? let me know what yall think n possibly some suggestions on what i should do thanks...
i would personally just get the mass air...I doubt that cam is too friendly with the speed density.
i look like i cant drive when im at a light... its not me it kills lol
you'll get much better gas mileage by doing the MAF conversion, but the carb will probably be more driveable and produce more power.
It really depends on what you are doing with the car... |
carb is really good an cheap for high hp applications..although efi has its benefits too..they both are basically a personal choice. carb has its downfalls as well does efi.
1987 Mustang GT
efi or carb?
id rather have efi any day, id do the mass air conversion. Look on e-bay i bought my kit for 400.00 with a 70mm meter
Threads Similar to: efi or carb?
| CARB OR EFI | BLACKNIGHT5.0 | 94-95 | 10 | August 16th, 2007 04:39 PM |
| efi to carb please help | itsmyfiveoh | 5.0 Mustangs | 33 | June 20th, 2007 03:26 PM |
| carb to efi | 347tt | 5.0 Mustangs | 5 | February 11th, 2007 09:08 PM |
| carb ? | terribleonexx88 | 5.0 Mustangs | 11 | December 4th, 2006 02:21 AM |
| V6 EFI vs Carb | quikstang2 | V6 Mustangs | 3 | August 17th, 2006 07:19 PM |
