new rebuild,big timing problems,need help
Old October 3rd, 2007, 08:02 PM   #1
tim si is on a distinguished road
i just rebuilt my 5.0 and installed a ford e-cam,ford racing timing chain,trick flow heads,bbk ssi intake,70 mm throttle body,42lb injectors,80 mm mass,new billit distributor.i check my timing and its so far off i cant read it.on the timing light its prob like 50 degrees,i know this cant be right.i can pull it down to like 30adv.but it wont hardly stay running.ive pulled the timing cover off and everythings fine.installed the cam,dot to dot.before the rebuild i had no problem setting the timing at 10 base.after some troubleshooting i replaced the balancer but its still the same.can anyone tell me what ive done?need help please.ive had a few people look at this and no one can give me an answer.
Old October 3rd, 2007, 08:45 PM   #2
ryans88gt's Avatar
WHat kind of balancer? My fluidampr reads 30 degrees at top dead center, so I had to remark this as zero. Double check your top dead center.
Also check that your distributor is pointing directly at the 1 position at TDC.
Old October 3rd, 2007, 09:01 PM   #3
distributor points right at the #1.im ashamed to say the balancer is from advance auto but the factory read the same.ill pull the piston up top tomorrow and see what i can find.is it really that common to get one that reads that far off?every one else tells me to just turn it til the motor frees up and run it there,but im putting a 60mm turbo on in a couple weeks and cant chance it without knowing where im at.
Old October 3rd, 2007, 09:47 PM   #4
Speedstang302's Avatar
13.64@101mph
whao whao...WTF are you doing with 42lbers..and with the 60mm turbo go like 60lbers..but 42lbs are HUGE for that..that will cause i nice problem when you get it running right..
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 3rd, 2007, 10:05 PM   #5
im having trouble following you.are you saying my injectors are too small or what.ive got stock bottom end,so ill only be running maybe 8lb of boost.what kind of problems do you think ill have?i went ahead and installed them before the turbo to get all the bugs out and its running pretty good right now,except the timing issue.alittle rich but not bad.
Old October 3rd, 2007, 10:57 PM   #6
ryans88gt's Avatar
well on my fluidampr the whole balancer body is welded, but it still reads 30 degrees off. I think it has something to do with the style of pointer you use. Different years have the pointer mounted in a different spot.
Are you setting the base timing with the pin pulled?
Anyway, bring it to top dead center, make sure the rotor in the dist is pointing straight back and note the location of the timing pointer. Your dist could be a tooth off, or your pointer is wrong.
As a side note, engines will run really well at like 40 degrees advance at idle. You may not have a timing issue, maybe just too much fuel. You could try turning the fuel pressure down.
Old October 4th, 2007, 09:36 AM   #7
13.64@101mph
42lbs are WAY TOO BIG...you should only have like 24lbs on max right now..put the 42lbers on when you get the turbo..but 60lbers would be better for that turbo
Old October 4th, 2007, 01:42 PM   #8
ryans88gt's Avatar
60 lb/hr injectors for a 60 mm turbo???
You so crazy....
60 lb/hr injectors are good for like 700 hp, you'll never see that with a 60mm turbo. 42 lb injectors are already good enough to split the block.
Plus at 8lbs of boost he'll be lucky to see 400 hp, so he really only needs 30 lb injectors for his turbo setup...
42 lb/hr injectors are big for his current set-up, but he should be able to get it running right with low enough fuel pressure (25-30 PSI at idle)
Old October 4th, 2007, 04:37 PM   #9
13.64@101mph
true..the 60lbs are to big for 60mm..got mixed up for some reason..but yeah 42lbers are huge for his current set-up..30 would be fine for the 400hp..
Old October 4th, 2007, 04:45 PM   #10
1987 ford mustang gt
well see when shes done
we all get screwed up sometimes
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old October 4th, 2007, 05:11 PM   #11
13.64@101mph
yeah i know..that was my token blonde gurl moment
Old October 4th, 2007, 05:23 PM   #12
i still love you come here big guy
Old October 4th, 2007, 05:42 PM   #13
13.64@101mph
Old October 4th, 2007, 05:45 PM   #14
Old October 4th, 2007, 06:31 PM   #15
Well i know my injectors are too big for my current setup,but whos gonna go buy smaller injectors to run for a month then put the 42s in.id rather go with 42s and cut the fuel back than30s and end up lean.ive also got a mallory comp fi.fuel pump with 8-an lines to and from the tank.at 32lbs of fuel pressure the car doesnt smoke any.im sure at some point ill go up to 10-12 lbs of boost and i wont have to worry about fuel.i may be wrong on my figures but if i make 350 hp now and i up the boost to 10lb,that should put me around 580 hp and if thats right ill be good on fuel
Old October 4th, 2007, 11:09 PM   #16
ryans88gt's Avatar
Yeah, that's alright, I figured you were just confused...
Old October 5th, 2007, 12:07 AM   #17
ujslost's Avatar
are you timing it on the compression stroke? Sounds like even though you have the #1 piston TDC and the rotor button pointing at #1 plug wire, that you might be on the wrong stroke. Tried pulling the dist up and turning the rotor 180 degrees?
Old October 5th, 2007, 09:30 AM   #18
13.64@101mph
he maybe 180 out already..and have to turn it back 180
Old October 5th, 2007, 12:04 PM   #19
i dont think it would run at 180 out,i was 1 tooth off and i guess the comp. was trying to compensate.its running at 14 adv. now,thanks
Old October 5th, 2007, 12:49 PM   #20
ryans88gt's Avatar
Threads Similar to: new rebuild,big timing problems,need help
c4 rebuild 342stroker 5.0 Mustangs 2 October 10th, 2007 12:57 PM
3.8 Rebuild arnett V6 Mustangs 5 October 9th, 2007 08:04 PM
Rebuild or Not to Rebuild? JERSEYTHUNDER 5.0 Mustangs 1 July 26th, 2006 11:39 AM
T3 rebuild help Cricket General Tech 3 July 6th, 2006 11:15 PM
help with a rebuild PERMustang 5.0 Mustangs 1 May 18th, 2006 10:20 PM
