quad shocks
Old August 2nd, 2006, 11:34 PM   #1
cali 5.0 is on a distinguished road
quad shocks
so how do i get rid of the quad shocks,
Old August 3rd, 2006, 12:56 AM   #2
11.21@123 -150 shot
orangeRcode is on a distinguished road
As long as you have aftermarket uppers and lowers you can remove the quads. Jack the car up. You will also need to jack under the rear to take the weight off of it. Remove the tire, remove the bolts and pull the quad off. Nothing to it.
Old August 4th, 2006, 12:08 PM   #3
dcraig8 is on a distinguished road
myself , i would keep the quad shocks. ford put them there for a reason, mainly for wheel hop. yes after market upper and lower control arms would take most of the wheel hop burden from the quads, but i replaced mine with koni quads, even though i have new lakewood upper and lowers and im quite happy with the whole setup
Old August 4th, 2006, 07:57 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes Ford did put them on for a reason. The reason was a poorly designed lower control arm. The oval bushing in the front is what causes the wheel hop. With aftermarket lowers you can throw the quad shocks in the garbage. Quad shocks are a factory band aid and nothing more.
Old August 4th, 2006, 09:58 PM   #5
don't forget you get more tire/wheel clearance when they're removed also.
88 Mustang Coupe
www.rickscarcare.net
Old August 5th, 2006, 01:33 AM   #6
IcantDo55 is on a distinguished road
Mine have been gone for a long time, no problems. I do have UCA and LCA.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Threads Similar to: quad shocks
quad shocks lone5oh 5.0 Mustangs 55 September 2nd, 2007 12:59 AM
quad shocks need or not Clockman 94-95 2 April 16th, 2007 05:26 PM
85 gt quad shocks 85slepr General Tech 4 June 7th, 2006 10:20 AM
Quad shocks gt96stang General Tech 6 April 11th, 2006 01:24 AM
Why no quad shocks megot02gt General Tech 5 October 27th, 2005 09:54 PM
