Adding and AODE to 1969 Fastback
Old August 3rd, 2006, 03:56 AM   #1
Stew Pididiot is on a distinguished road
I couldn't figure out whether I should post this here or in with the classics--but the question seems primarily geared toward the late-model parts, so this forum seemed most appropriate.
I have a 1969 fastback with a stock 302. The carb was replaced with a throttle body fuel injection system. I just scored two trannys-- an AOD and an AODE. I want to replace the C-4 thats in the car now with the AODE.
I dont have the computer that runs the AODE. I believe the unit came out of a 1994 T-Bird. I'm planning on going to the salvage yards to find the transmission computer, wire harness, dipstick tube and other misc. parts. Do I need to find another 94 T-Bird, or will any AODE loaded car have compatible parts for this trans?
Any help is appreciated!
Old August 3rd, 2006, 07:23 AM   #2
there is no dedicated trans computer. it's part of the engine pcm. Ck out TCI as they have some dedicated trans controllers that will make this swap much easier
88 Mustang Coupe
www.rickscarcare.net
Old August 8th, 2006, 03:13 PM   #3
Thanks. I guess the real question is-- can you somehow use the original late-model PCM solely for transmission control, without engine control? Those aftermarket boxes are really expensive!
Threads Similar to: Adding and AODE to 1969 Fastback
1969 Mustang Mach I UnderAlias Classic Mustangs 3 May 20th, 2008 08:53 PM
1969 mercury cougar BWAL All Other Vehicles 25 September 26th, 2007 11:02 PM
Need Some More Help (1969 Coupe) 67GT350 Classic Mustangs 5 January 12th, 2007 05:42 PM
