Tire Setup
Old October 6th, 2007, 12:35 PM   #1
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
Tire Setup
Anyone here know if M/T 255/50/R16 Radials mounted on 16x8-in '95 Cobra R wheels will fit in back of a fox?
Old October 6th, 2007, 10:15 PM   #2
Racinjason81 is on a distinguished road
if i can fit 275/40/17s on 17by9 03 cobra wheels on my fox i dont see why your setup wouldnt fit.you definitelyshouldnt have a problem
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old October 6th, 2007, 10:26 PM   #3
Speedstang302's Avatar
13.64@101mph
cuz you barely have tires on there 40's????
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 6th, 2007, 11:12 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
A 255/50/16 is only about 1/4 inch taller then a 275/40/17 which means it will only sit up in the fender well about an 1/8 in more. It is also just over 3/4 of an inch narrower so with the same rim backspacing, it would be 3/8 in further away from the fender and the quad shocks if still installed.
Those numbers do not mean it will fit but the two are not that different in height.
Old October 6th, 2007, 11:22 PM   #5
13.64@101mph
jasons rims are 17's and stangs are 16's...there one difference..and another added to that jasons tires have smaller tread hight..so means stang can fit bigger tires..
but technically you could fit 15X10 with 295/50/15's but with a little fender messaging..actually alot..
Old October 6th, 2007, 11:35 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
I did the math which included the different rim sizes.
What is the tread height difference between the two tires?
Old October 7th, 2007, 08:24 PM   #7
well...im a hop and a skip away from buying an 88 gt and i already have the wheels. Two of the wheels already have 245/50-16 tires on em...I intend on using those in the front. I just wanted to mount some et streets in the back for more traction... I'd run welds, but i'd be cheaper to work with what i have for the time being so i wanted to mount the streets on the cobra Rs and make do.. but Thanks for the help guys...i really appreciate it.
Threads Similar to: Tire Setup
The new setup Tony_90fox Videos 12 August 8th, 2007 06:12 PM
The new setup! Tony_90fox The Clubhouse 6 August 7th, 2007 09:57 PM
Front drag wheel and tire setup? 03_StangGuy 99-04 1 July 29th, 2007 11:36 PM
New Setup :-) 98SilverBullet 96-98 34 June 2nd, 2007 03:23 PM
Biggest Tire And Rim Setup Possible 5.0 street stanger 5.0 Mustangs 3 October 15th, 2006 12:50 AM
