miss at 3500 under load...
OK I know my ignitions pretty well, but I aint too proud to ask for help.
My dad always said someone who knows something well knows when to ask questions. I thought yall might have a shortcut through the troubleshooting. I have not yet replaced the cap, rotor, plugs, wires, coil, module, or distributor yet. the car runs GREAT under light load at normal driving speeds. I set the timing to the final position today and its smooth as it can be and gets to speed with a purpose. only one issue right at about 3200-3500 RPM underload (accellerating or hitting passing gear): a miss of some kind and when I get back below 3200 or so I can get on it all I want untill it goes back up to 3200 or so. this is confusing to me, it doesnt miss under load at a powerbrake, or anywhere under 3200 RPMs. I thought there might be a Mustang specific issue to explain this. I was thinking I needed a stronger spring ratio for the mechanical advance, because it was hitting full advance too soon, only to find out there is no mechanical advance. I dont have the time to troubleshoot it today, and since I just got out of surgery a few days ago, its prolly not a good idea anyway. My best guess is the module or distributor.... Any suggestions Y'all? Thanks Daniel ![]() EDIT: this is a speed density, 1988 GT HO drivetrain, stock. |
I drove it to work today and no new issues.
lit up second gear (even with the miss) when I went to pass a truck...that was fun ![]() It seems to be intermittant....but temperature seems irrealavant, does it cold or hot. I am going to replace the cap, rotor, wires and plucgs this friday, and the module too if I have the money. I am hoping its not the Distributor itself.... Daniel
13.64@101mph
MSD 6AL box
MSD TFI coil MSD cap and rotor MSD 8.5mm Super conductor wires and bosch, motorcraft or accel spark plugs.. the cap and rotor maybe bad, or a spark plug wire would be in the wrong spot causing it to run 2 cylinders down..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
[quote="Speedstang302"]MSD 6AL box
MSD TFI coil MSD cap and rotor MSD 8.5mm Super conductor wires motorcraft spark plugs.. quote] X 2 I am looking for performance upgrades in March when I get back, right now Ill start troubleshooting in the next few days. I know its not 2 wires, that would miss under load in a power brake too.... Im starting with the cap and rotor and going to wires and plugs. Hopefully that will help for now. |
Before you spend too much money, try replacing the plug wires first. I had the same problem and I found out that the wire boots on the mustang are real close to the header manifolds. I went through a number of wires until I found a boot that didn't burn through.
what kind of wires is that? i bought the msd 105 dollar ones....seem to work ok but still to close to the manifold for me....
If the problem is intermittent, when does it do it? Has there been moisture when you have experienced this problem? I wouldn't be looking at swapping over to an MSD ignition unless you have money to throw away. It is totally unneccessary at this point. The factory TFI system is a good system. I'd be looking at cap, rotor, plugs and wires for starters. Leave the module alone. The symptoms you are experiencing are not symptoms of a bad ignition module. Its very doubtful that its the distributor itself.
I had a similar issue and I believe it was because of my spark plug wire routing. I had a couple of places where the wires were crossing over each other. Again though, it could be anything in that spark path.
I have a rant about spark plug wires as well. I've had a few expensive pairs and some relatively cheap sets and some generic brands. I can not say that any one of them was better then the other. Too me, the price had nothing to do with the quality. Maybe on a 7000+ rpm car it makes a difference. I have a set of Bosch 8.5 plain old gray for $40 and they have been going fine for a few years. My only complain with them is the wires for 4 and 8 are a little too long.
#9 | |
If I take it easy and run it up to 3500-4000 RPM, it does fine. If I put it under loead (heavy accelleration or in passing gear) it starts jerking at about 3200 (give or take a few hundred RPM) what I meant by intermittant is that it doesnt happen EVERY time I hit that speed, but only under load. After the advice on here, Ill try the wires first, and go from there, these wires arent new and they ARE awful close to the headers. Ive had excellent luck with Accel and MSD wires in Header applications. Ill start with the MSD Superconductors. ![]() I will be up to bending and lifting and such this weekend, so Ill get on it then (besides Friday's payday) Thanks everyone, I will post up results as soon as I have them. Daniel
13.64@101mph
i havent had any problem with my msd superconductors, and darrel i just told him msd 6al box would be nice upgrade, never said he original is the problem..
#11 | |
I am planning alot.... Ive used MSD on everything else Ive built and I Love it. I like the way the original ignition runs too, so Im not planning anything right now. Got to have a good running car before you can mod it. Daniel
#12 | |
1990 LX hatch
#13 | |
1987 ford mustang gt
well see when shes done
13.64@101mph
mine were $95, but i have a discount there and they were $65..
#15 | |
I'll get yall some answers this weekend when i replace the wires. Daniel
#16 | |
Will do. I should be able to get some wires on Friday, I also have the following to do (busy weekend):
both Ft brake lines both ft rotors/calipers/pads GT rocker trim some kind of cohesion with the color of the car...lol (prime grey )so I should be a busy dude this weekend, everythings been backing up since surgery last wednesday. Doc says I can start working Friday so its on...lol Daniel
OK Heres what I did:
MSD 8.5MM Superconductor wires New Cap New Rotor New Ft brakes, rotors, bearings and brake lines First of all, I found a wire with a nasty spot on it, hiding down on the boot. Miss identified. Now no miss at all, but a problem persists: up around 4-5000RPM I get some hard Predetonation.... I got the Timing set on Factory settings (10 deg which seems quite HIGH in my opinion) and everything is new except the coil and module. I would say that the timing was awful high and it was at full advance before it could get up there...but everything is at factory settings so it should be running right... I think it's got to be an electrical (ECM) issue or something...perhaps the module? the car runs GREAT even when its predetonating, but I let off of it as soon as I hear it and I know it shouldnt do that, even at 4-5000 RPM. I will be back under the hood today and getting the driver's side GT rocker trim finished up so I will have more info later... but any Ideas? Thanks Everyone Daniel
Try running some higher grade gas. What spark plugs are in the car? Do you live in a high altitude area? What is the engine temp when this occurs? How about outside air temp?
Outside Ait Temp: about 55-60 deg
Engine temp: Normal, 1 notch under halfway up. Stock Motorcraft Spark Plugs Athens/Ardmore, AL....dont think we'd be classified as High altitude, but we arent LOW altitude.... we are 5 miles South of the Tennessee Border. Running 87 OCT right now, I will try running 93 in it on the next tank, but my budget wont let me do that more than once...lol this was last night around 9:00 or so. Does it every time Im on it above 4000... prolly what was causing the other issue to be so bad at certain RPMs... Daniel
Threads Similar to: miss at 3500 under load...
| rough idle, bog @ 3500 RPM | Lmagee | 5.0 Mustangs | 11 | September 19th, 2007 02:01 AM |
| pinging when under a load | cobraetti | 5.0 Mustangs | 4 | April 28th, 2007 11:42 AM |
| 1991 Mustang 5.0 $3500 | Paul Charland | 5.0 Mustangs | 9 | December 21st, 2006 01:08 AM |
