c4 rebuild
Old October 8th, 2007, 03:19 PM   #1
342stroker is on a distinguished road
c4 rebuild
I am going to rebuild a c4 this winter, first time doing one, was going to pick up a kit from P.A. or B&M with all the clutches and seals, etc. Does anyone have any advise or know of any special tools out their that are needed.
Old October 9th, 2007, 12:16 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
C4s are pretty simple to rebuild. An easy way to do it is to take the parts out and stack them in the order that you took them out. That is the way I did my first one.
Old October 10th, 2007, 12:57 PM   #3
tomzac is on a distinguished road
I'm pretty sure you'll need a good set of snap ring compressors/expanders. It's been years since I build my last c4/c6. Can't some of the clutch drums be replaced with ones that use more steel/clutch discs? And replace the planetaries with stouter pieces? There are other things that can be done to help reduce fluid transfer time to allow better shifting.
2002 Summer Beater
Threads Similar to: c4 rebuild
3.8 Rebuild arnett V6 Mustangs 5 October 9th, 2007 08:04 PM
To rebuild? hudini 4V / SVT 2 September 30th, 2007 09:47 PM
A little help after the rebuild? mikebert 5.0 Mustangs 28 August 16th, 2007 03:55 AM
Rebuild or Not to Rebuild? JERSEYTHUNDER 5.0 Mustangs 1 July 26th, 2006 11:39 AM
help with a rebuild PERMustang 5.0 Mustangs 1 May 18th, 2006 10:20 PM
