the idling kinda sucks
Old October 9th, 2007, 09:25 PM   #1
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
my 1988 mustang gt with a computer from 1989, c&L maf conversion idles like poo until fully warmed up. It will stall at first turn of the key, and i literally have to be gassing it (i keep it at like 1400 rpm) for 20 seconds and then until 3-4 minutes later its barely keeping itself alive. Then it idles fine once it warms up. Can i clean something? Do i have a serious problem? IMO i think for ME its a serious problem, i want to be able to turn that damn key and ITS EFI!!! it should keep itself going! thanks alLl!
Old October 9th, 2007, 10:06 PM   #2
1BADSTANG's Avatar
poo
Old October 10th, 2007, 12:00 AM   #3
TENGRAM is on a distinguished road
Re: the idling kinda sucks
here's what i would do if i were you. i would go back over every detail of the mass air conversion and make sure i did everything right. if the problem persists then i would clean the IAC and make sure it is working properly and i would Check for Codes including the cylinder balance test. then i would post my results on here and see if TENGRAM can help diagnose the problem
good luck
89 GT t5 3.73
www.my5oh.com/
Old October 10th, 2007, 12:06 AM   #4
good luck
yeah, what he said!
I would personally do the easy stuff first...Clean the IAC, and clean the MAF. If that doesnt solve it, go back through the conversion. lol
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old October 10th, 2007, 12:14 AM   #5
331LX89 is on a distinguished road
had similar problems with different cars slim chance but check temperature sensor for computer(two wire sensor) if its unpluged or bad the it will read somewhere around -40 or so below and dump fuel therefore having to gas it,but when it warms up the temperature in the cylinder helps burn off the extra fuel
89 Mustang LX
331ci 7.88@87.72mph
Old October 10th, 2007, 02:24 AM   #6
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
its probly not as simple as this but my car was doing about that exact same thing and all my problem was a vacum hose that had broke from dry rot.....i fixed it and it immediately fixed the idleing
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old October 10th, 2007, 03:18 PM   #7
ryans88gt's Avatar
What injectors and fuel pressure are you using.
2 things I would try,
1) try rotating the C&L mass air. My car idles best with the MAF at about 2 o'clock, instead of 12 o'clock. By rotating the MAF it picks up a different air signal which can greatly affect the idle quality.
2) try lowering your fuel pressure by 5 PSI if you have an adjustable fuel pressure regulator.
C&Ls are known for poor idle quality, welcome to the club.
Old October 10th, 2007, 04:57 PM   #8
Speedstang302's Avatar
13.64@101mph
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 10th, 2007, 06:37 PM   #9
it sounds like he's still got 19 lb injectors and the right C&L for them, so that should not be causing his idle issue. mine idles perfectly and i hve seen many many others with C&Ls have no idles problems.
89 GT t5 3.73
www.my5oh.com/
Old October 10th, 2007, 07:41 PM   #10
13.64@101mph
yeah alot of people for some reason have problems with there C&L MAF sensors, i have an C&L 76mm MAF and have had no problems with it..
i say maybe the IAC is bad
Old October 10th, 2007, 08:24 PM   #11
JBIGBOOTSY's Avatar
1990 LX hatch
I was gonna say that someone told me that too, But it was you. Anyway It Idles better with less pressure and clocked at 2:00
Old October 11th, 2007, 12:31 PM   #12
ryans88gt's Avatar
Yeah, Rick Anderson is the one that gave me this tip...
he is also the one that told me C&Ls are known for their idle problems
Old October 11th, 2007, 09:23 PM   #13
patwrecked is on a distinguished road
check timing]
Threads Similar to: the idling kinda sucks
Idling Weird... 97GT4.6 96-98 12 November 10th, 2007 01:21 PM
Idling problem dothedew1654 94-95 9 November 3rd, 2007 05:01 PM
idling problem 02MiNeRaLgRaYGT 99-04 6 October 19th, 2007 06:29 PM
idling afmustanglover General Tech 7 April 4th, 2007 10:39 AM
My 86 idling 5literJeff Videos 1 January 18th, 2007 05:26 PM
