idles crazy some times
Old October 11th, 2007, 01:30 AM   #1
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
K my 86 5.0 has been sitting for 3 years i go out and start it atleast once a mounth some times it will idle high and i try to kick it down and it goes higher some times its fine i put a new tps on it before i parkedi was driving it and it stuck at 4000 rpm and it was fine after that any sugestions map maybe ?
Old October 11th, 2007, 01:32 AM   #2
IAC? Check all the vacuum hoses and look for leaks?
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old October 11th, 2007, 01:40 AM   #3
86ttops's Avatar
n/a
dont think its vacum doesnt do it all the time
Old October 11th, 2007, 02:00 AM   #4
patwrecked is on a distinguished road
check the linkage uder the throttle body, make sure it isnt caught on anything. loosen the nut that sits behind the spring in the throttle cable( underneath the tb), not the idle set screw. if all else loosen mess around with the idle set screw with the engine running. also lubricate all the linkage.
Old October 11th, 2007, 02:01 AM   #5
it may also be the iac but i doubt it.
Old October 11th, 2007, 02:05 AM   #6
then again if the iac is the origional, then buy a new one. they list for like $90, but u can get then way cheaper at kragens. its all the same crap.
Old October 11th, 2007, 03:00 AM   #7
TENGRAM is on a distinguished road
linkage is catching on something or the TB blade is getting stuck open. otherwise it is likely that you have an intermittant open in your TPS wiring. Check for Codes to find out if its the TPS wiring.
i'm doubting it is the IAC because, although it can make your idle stick high (2k rpm), it does not have the ability to raise it that much (4k rpm). keep us updated
89 GT t5 3.73
www.my5oh.com/
Old October 11th, 2007, 09:37 AM   #8
Speedstang302's Avatar
13.64@101mph
i had the same problem, wd40 on the throttle linkage and never had the problems again..
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 11th, 2007, 11:25 AM   #9
86ttops's Avatar
n/a
There are no codes and its not the linkadge blade is closed i have mass air and a9l for it but dont want to put it on untill i get this fixed
Old October 11th, 2007, 12:33 PM   #10
ryans88gt's Avatar
I have no idea how your car can idle at 4000 rpms unless you have a massive vacuum leak or your throttle blade is getting hung up.
Even if you IAC was stuck all the way open it wouldn't idle up to 4000.
It has to be getting air from somewhere to idle that high...
Old October 11th, 2007, 12:39 PM   #11
nolife's Avatar
91GT, 88GT, 02GT
A mouse stuck in the throttle plate? My car that sits for long periods gets them all of the time, besides the air box, they seem to like the area between the upper and lower manifold. Have not found any in the actual intake through. That would suck... literally.
Old October 11th, 2007, 04:56 PM   #12
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
+1
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old October 11th, 2007, 05:15 PM   #13
so you checked codes and got a code 11 (meaning everything is ok) for the first three tests and a 9 (meaning all cylinders are functioning identically) for the cylinder balance test?
FYI, just because your CEL isn't on does not mean there are no codes... with it idling at 4k rpm there will be codes, i guarantee it.
89 GT t5 3.73
www.my5oh.com/
Old October 12th, 2007, 01:12 PM   #14
86ttops's Avatar
n/a
It wasnt at 4000 rpm just high like 1200 or so
Old October 12th, 2007, 01:13 PM   #15
86ttops's Avatar
n/a
My buddy ran them for me and all he came up with was a bad temp sensor I cnat test it when it is doing it the high rpms are not good on the motor
Old October 12th, 2007, 05:02 PM   #16
ryans88gt's Avatar
Re: idles crazy some times
Old October 12th, 2007, 10:00 PM   #17
13.64@101mph
Y....E......A.....H??????? :homo
Old October 13th, 2007, 10:50 PM   #18
86ttops's Avatar
n/a
That was befor e changed the tps now its like up too 2500
Threads Similar to: idles crazy some times
My Car Idles Like Shit cali 5.0 5.0 Mustangs 25 November 8th, 2007 06:06 PM
4.10 are in now car idles really high and wont shift Timm10221 5.0 Mustangs 5 October 12th, 2007 07:00 PM
car idles wierd now 00GT 99-04 7 August 19th, 2007 03:53 PM
idles like shit 91foxhatch5.0 5.0 Mustangs 3 June 21st, 2007 06:04 PM
Can 1/8th mile times give est 1/4th times? Nightstick Drag 3 April 16th, 2006 10:20 PM
