T-5 to T-56 swap and exhaust issues
Old August 7th, 2006, 02:27 PM   #1
bgddy50's Avatar
1991 LX Mustang
bgddy50 is on a distinguished road
Does anyone out thier have any advice on recoomended exhaust modifactions. Here's where Im at, I've installed the t-56 and frogetting that the T-56 Trans is longer than the T-5 I now have exhaust fit problems with my BBK High flow CAT X pipe. The new location of the trans cross member is directly in the path of where the cats should be located. Any help with my delema is greatly appreciated.
Old August 7th, 2006, 03:34 PM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
id suggest doing away with cats, but in ca you have to pass emissions, although I have seen some tunes set up where theyll pass w/out cats
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 7th, 2006, 07:43 PM   #3
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
:homo If you can get away with it i would just remove the cats all together.
Old August 7th, 2006, 08:15 PM   #4
YsOffcr's Avatar
YsOffcr is on a distinguished road
Send a message via AIM to YsOffcr
Try and find a local exhaust shop to fabricate one for you, if you have to keep the cats. If not I'm with everyone else, get rid of them.
check out my gotstang.com page
Old August 7th, 2006, 10:12 PM   #5
bgddy50's Avatar
1991 LX Mustang
I have run with out them in the past however, road side spot checks caught me. Car was towed and 375. fine to go with my tow fees. The cats Im not worried about its the X pipe fitting. Since installing the T-56 mount sits back about 6-8 inches which has screwed the whole fitment. I think Im looking at a custom exaust
Old August 9th, 2006, 01:50 AM   #6
YsOffcr's Avatar
Will an H-pipe fit any different? Or would it have the same problem?
Threads Similar to: T-5 to T-56 swap and exhaust issues
New guy with issues. 01GT 99-04 9 May 25th, 2007 03:59 AM
Clearance issues Pharoh V6 Mustangs 9 April 22nd, 2007 03:21 PM
I am having exhaust issues! 06GTstang06 General Tech 4 December 19th, 2006 03:33 PM
new here, wanna swap exhaust on 2003 Mach01 WhoIsLion 99-04 9 October 19th, 2006 11:59 PM
93 5.0 with issues hrsepwr44 5.0 Mustangs 2 May 9th, 2006 12:36 AM
