fuel lines
Old August 7th, 2006, 05:16 PM   #1
2ToneFox's Avatar
2ToneFox is on a distinguished road
fuel lines
when i turn my car on i get a leak.. thier is gas dripping from under the muffler.. i belive its a rusted out gasline.. am i right?
Old August 7th, 2006, 05:21 PM   #2
OTreborO is on a distinguished road
Re: fuel lines
Probably: Please include more information. Are you sure it is gas that is leaking? Where is it leaking? I guess it could be a defective/old fitting and the gas is running down the line and dripping at the lowest point.
Is it a 4 cyl or 8 cyl. The lines are run on different sides of the car, and different fittings are used depending on which engine you have
Trebor
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old August 7th, 2006, 05:30 PM   #3
2ToneFox's Avatar
fuel lines
its a 8cyl. and the leak is comming from the passenger side and im sure its a gas leak bec i smell it
Old August 7th, 2006, 06:16 PM   #4
stang fanatic's Avatar
stang fanatic is on a distinguished road
id fix it before you lite yourseld up. line probaly rusted through or a connector is leaking on the plastic line portion
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Threads Similar to: fuel lines
Braided Fuel Lines gotboost562 5.0 Mustangs 11 October 11th, 2007 04:01 PM
Fuel lines JBIGBOOTSY 5.0 Mustangs 2 August 31st, 2007 07:10 PM
Removing fuel lines? Tony_90fox 5.0 Mustangs 3 July 7th, 2007 11:39 PM
Fuel Lines terribleonexx88 5.0 Mustangs 3 February 28th, 2007 10:58 PM
Do I Have To Swap The Fuel Lines? OTreborO General Tech 1 November 9th, 2006 08:31 PM
