fuel pump wont shut off. - Forums at Modded Mustangs
post #1 of 15 Old October 13th, 2007, 01:15 AM Thread Starter
anybody have any suggestions? It only shuts off if I unhook the battery.
1988 Mustang GT
squirt is offline
post #2 of 15 Old October 13th, 2007, 01:17 AM
possibly bad ground or wired wrong!!..where do you have it mounted? and who makes it?
is its a external electric pump or internal electric..is it even electric?
2004 40th Anni Redfire GT- Cold air, Magnapack Catback, Mach 1 Chin Spoiler, Mach 1 Grille Delete, Cobra Mirrors, 18x9/10 Chrome Saleens
Speedstang302 is offline
post #3 of 15 Old October 13th, 2007, 01:43 AM Thread Starter
stock fuel pump...electric in-tank.
1988 Mustang GT
squirt is offline
post #4 of 15 Old October 13th, 2007, 01:45 AM
does the car run decent or way too rich
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Iownastang is offline
post #5 of 15 Old October 13th, 2007, 10:59 AM Thread Starter
Its seems to be running O.K. are you leaning toward a toggle switch.
1988 Mustang GT
squirt is offline
post #6 of 15 Old October 13th, 2007, 09:18 PM
look at the fuel pump and look for the ground. the ground my be dirty. if it is disconect it and get a wire brush or sand paper and clean it of.
I think this may be the problem becuase this happened to my friends car.
Fast98stang is offline
post #7 of 15 Old October 13th, 2007, 09:49 PM
always clean all the grounds, safest and smartest thing to do
post #8 of 15 Old October 13th, 2007, 10:26 PM Thread Starter
O.K. here' the problem now.....I turn the key on to check codes and the engine light comes on and doesn't go off. Hook up a jumper and turn the key on and no codes, the light just stays on. Usually the fuel pump goes off after its primed, but it constantly runs. Sorry so long just getting frustrated.
1988 Mustang GT
squirt is offline
post #9 of 15 Old October 13th, 2007, 10:27 PM Thread Starter
It doesn't even start now, just cranks not even a sputter.
1988 Mustang GT
squirt is offline
post #10 of 15 Old October 13th, 2007, 10:55 PM
86ttops's Avatar
Send a message via Yahoo to 86ttops
fule pump relay stuck? should be in passenger kick panel mine is
86ttops is offline
post #11 of 15 Old October 13th, 2007, 11:05 PM Thread Starter
relay isnt stuck...if I turn the key on, then off, the pump goes off. If I leave the key on it constantly pumps.
1988 Mustang GT
squirt is offline
post #12 of 15 Old October 13th, 2007, 11:07 PM
86ttops's Avatar
ic sounds like some type of presur switch if it has one sory couldnt help
86ttops is offline
post #13 of 15 Old February 7th, 2008, 08:48 PM
Send a message via AIM to proracer97
theres a relay either uner the drivers side set or under ur intke its prolly stuk sam thing happenedx to mine
proracer97 is offline
post #14 of 15 Old February 7th, 2008, 08:51 PM
hey man this thread is 4 months 0ld
post #15 of 15 Old February 8th, 2008, 12:27 AM
Sounds like a stuck relay. Just turning the key on and off doesn't mean it isn't stuck. It means it's getting 12volt power all the time, which comes from the relay as switched by the computer. If the relay is stuck, the power is on all the time.
rwfisher is offline
Human Verification
