Stock cylinder head chamber size??
Old October 13th, 2007, 10:13 AM   #1
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
What cc is the stock cylinder heads chamber on a 87 mustang ?
Old October 13th, 2007, 11:23 AM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
64cc I believe.
Old October 13th, 2007, 09:19 PM   #3
Speedstang302's Avatar
13.64@101mph
Originally Posted by JBIGBOOTSY
64cc I believe.
is it?? i thought it was like 57/58cc but i could be wrong!!
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 14th, 2007, 12:50 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
roughly 61.5cc
Old October 14th, 2007, 06:33 PM   #5
The Razor's Edge
White Thunder's Avatar
...... flow......
intake side is 127cc and exhaust is 44cc and intake ports 160cfm......and exhaust 112cfm
around 328 is the max horsepower you can get on stock heads.....
founder of the FTN Club
Old October 14th, 2007, 09:12 PM   #6
13.64@101mph
Originally Posted by Darrell
roughly 61.5cc
OK..i knew it was like somewhere between 57-65...
Old October 14th, 2007, 09:54 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've actually found them to vary from chamber to chamber on the same head. Gotta love assembly line production work.
Old October 14th, 2007, 10:18 PM   #8
13.64@101mph
They do do good work
Threads Similar to: Stock cylinder head chamber size??
DIY cylinder head porting 99v6stang V6 Mustangs 9 July 25th, 2007 08:59 PM
Pictures from cylinder head change... acmillr 99-04 62 March 3rd, 2007 09:54 PM
3-VALVE RH CYLINDER HEAD TDog 2005 - 2010 0 February 22nd, 2007 04:10 PM
Cylinder head shaving acmillr 99-04 1 January 8th, 2007 10:34 PM
Help CYLINDER HEAD, TWISTED WEDGE stang94 5.0 Mustangs 10 December 29th, 2006 11:20 PM
