Discussing 302,306,347,351-which motor would be best on boost (turbo) in the 5.0 Mustangs Forum. which displacement would suite best for boost on the street... and would it be able ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
302,306,347,351-which motor would be best on boost (turbo) |
I Do Stuff...
SLOW
You could use a 351 stroked out to like a 357 or so...It really depends on what else you plan on doing to the car and the engine...
1999 Ford Mustang V6
i don't think displacement would matter all that much in comparison to compression ratio... all of those combinations can be made streetable and run into the 10's if setup right.
...even fire and single cammin |
#4 | |
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Bigger is better. Build the motor as big as you can afford. But like has been mentioned, to run 10s with boost can be accomplished with any one of the mentioned engines. Alot of guys in my area are running 10s with stock 5 liter short blocks with blowers.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
right on about the compression but i went with the 347 because it has good torque all by itself
Threads Similar to: 302,306,347,351-which motor would be best on boost (turbo)
| COMPRESSION FOR TURBO MOTOR? | sn-95aac | 5.0 Mustangs | 14 | May 28th, 2007 05:23 PM |
| Boost controller and turbo timer | trueballerisme | V6 Mustangs | 1 | February 28th, 2007 11:55 AM |
| Turbo Boost vs Super Boost | droppedbass87 | Poweradders | 12 | October 16th, 2006 09:56 AM |
| Custom Turbo Timer, And Boost Controller Pod | Cricket | Poweradders | 16 | July 25th, 2006 11:44 PM |
| does this setup sound good for about 18lbs of turbo boost? | frankenstein | 5.0 Mustangs | 2 | July 16th, 2006 11:29 PM |
