Suggested injector size??
Old October 14th, 2007, 10:27 PM   #1
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
ok im going to be changing my setup and was curious what size injectors i should get, i was thinking 42's but let me know what you guys think. My setup is going to be trick flow heads, stage 1 or 2 cam ( have yet to decide), typhoon intake manifold, novi 1000 supercharger (going to crank the boost up to approx 8 pounds), 70mm throttle body, 90mm mass air meter, afm power pipe, bbk shorty headers, bbk or x-pipe, flowmaster cat back. Do i need to install an inline pump for 42's i already have a 255 in tank?
Old October 14th, 2007, 10:51 PM   #2
Speedstang302's Avatar
13.64@101mph
42lbers will be fine, i'd get an AFPR too...
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 14th, 2007, 10:54 PM   #3
jam77's Avatar
1987 Mustang GT
yeah i got one already and im going with a pms to tune it. Do i have to get an inline pump to drive the 42's if i have a 255 lph in tank pump?
Old October 14th, 2007, 11:01 PM   #4
ryans88gt's Avatar
I certainly wouldn't go any bigger than 42 lb/hr, you should be good to about 500 HP with those.
you will not know if you need a booster pump until you monitor the fuel pressure on the dyno. You'll probably be OK without it.
Old October 14th, 2007, 11:16 PM   #5
jam77's Avatar
1987 Mustang GT
would 30's be enough?
Old October 15th, 2007, 02:41 AM   #6
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
i found this equation for injector size
motor horsepower / 8 * .50 / .85
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old October 15th, 2007, 09:37 AM   #7
13.64@101mph
that says 36lbers are good for 500hp
and 42lbers for 600hp..
i well what hp you pushing to the crank..cuz 30lbs with a s/c maybe too small
Old October 15th, 2007, 09:57 AM   #8
nolife's Avatar
91GT, 88GT, 02GT
That equation is a good start.
Try this online calculator page for a little more detail and a description of that equation.
http://kgparts.com/index.php?page=fuel-calc
Here is another page with some maximum numbers for different injectors which assumes 100% duty cycle which is not something you should be at anyway.
http://www.motorsportsdigest.com/tech/perform2.htm
Old October 15th, 2007, 04:01 PM   #9
vfast will become famous soon enough
keep using charts as they really don't mean shit , just a starting point
dude you need and inline pump I will not install any S/C without one...want to know why? what if the intank pump fails on a high rpm run, we all know..but with a 75 lph or even a 110 lph you can atleast save the engine and can even limp it home. as for cam I couldn't say unless I had more info...the stock cam also works great in the 5-7 psi range with some longer rocker, even the terrible e-cam work well with it
Old October 15th, 2007, 05:53 PM   #10
1990 Mustang GT
As the saying goes better safe than sorry.....its always better to have injectors a lil too big than too small....running rich isnt near as bad on an engine as running lean
1990 GT
2004 Impala SS
2001 Tacoma
Old October 15th, 2007, 06:20 PM   #11
so very true! a tuner is almost a must with 42's unless you like having to push the pedal to the floor to start it up
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old October 15th, 2007, 08:13 PM   #12
jam77's Avatar
1987 Mustang GT
im just going to order 42's and be done with it, i will put in a t-rex or some other inline pump just to be safe, i will be running a pms so that should take care of the hard start.
Old October 17th, 2007, 12:40 AM   #13
ryans88gt's Avatar
If the intake pump fails, god himself couldn't suck an ounce through it, so it wouldn't matter if you had an inline pump or not (which only push, the don't pull). You cannot draw through a non-functioning intank pump, it would still run lean and blow up. A 110 lph inline pump would slow down a 255 in tank pump. If you have a 255 intank pump, you need a 255 lph boost pump, there is no mixing and matching here.
Threads Similar to: Suggested injector size??
Injector Size mmvi V6 Mustangs 11 November 10th, 2007 04:11 PM
Injector size and MAF conversion? Never2fasst 5.0 Mustangs 1 August 28th, 2007 04:16 PM
Fuel injector size/colors? fastsvtss 5.0 Mustangs 3 April 19th, 2007 03:40 PM
Fuel injector size? WAR-PARTY 5.0 Mustangs 4 February 19th, 2007 09:50 PM
injector size? 92_LX_5.0 5.0 Mustangs 6 February 11th, 2007 01:42 AM
