what do you think it will run
Hopefully tomarrow if it does not rain, were going to the track, chances are last for the year. What do you think my girls car will run in the 1/4
it is a 91 vert. with a fresh 306, T.F. stage 1 cam., cobra intake, 65tb, 73mm mass, full exhaust,paxton sn2000 blower(around 6,7#), ignition upgrades and 255 pump, fresh stock heads,3.73 rear, automatic shifting manually(well used, but still shift hard with alittle delay), a stall con. around 2500 and mickey streets. Also took alot of weight off including, all emissions, cats, air pump, egr, air cond, added tubular k and have a glass hood, and just installed steedas sub frames, what a diff that made. absolutly no tuning done other then tweaking the fuel pressure, and right now running 10degrees of timing, she has the ignition box with the boost retard yet but we havent played with it yet. it pulls nice on the top end right up to 6000 were hoping for atleast 13.50s in the 91, and i will be taking my 96 cobra bone stock, with just magnapack catback and kinda shitty tires, I know ive seen all the stats, that its suppose to run around 14.0, but with the tire who the fuck knows. |
if that car run a 13.50 you have issues.....my basically stock hatch runs 13.78
the maf is too small on that car and a 70mm t/b will also help....you said tube k did you use coil overs?
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
13.64@101mph
my guess if its built right or close to it it should run mid 12's...i have basically GT40 top end w/ fcam, and alot of other small stuff, 3:73's and alot of suspension it ran 12.86 w/ slicks..so if you only run 13.5...you have a hole somewhere!!
