Discussing Help!!!Serious Charge problems in the 5.0 Mustangs Forum. I am having some serious charging problems. First of all I just got back from ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
'95 Blk GT....Complete Magnaflow exhuast with o/r H-pipe...CAI...PVC system by-pass...25%Underdrive...9mmFRPP wires...Smog pump delete...Battery relocate...Intrax 3inch lower...Hurst shifter...3.73's...Interior renos |
you bought a rebuilt...probaly went bad...typical problem with rebuilt products
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
Yeah that's what I am thinking. Could it be the underdrive pulleys as well. How can I check to se if it is the alternater?
rev the engine to 2000rpm and then full field the alternator buy grounding the regulator screw on the back. If the alt is good, it will charge wide open. Or remove the alternator assembly & take the alt to autozone and have them ck it on their machine to see if it's charging correctly. Most of the u/d pulleys for the alternator limit their charging ability quite a bit. You can put the stock pulley back on the alt and it will improve
88 Mustang Coupe 2006 FFW Richmond True Street Runner-Up www.rickscarcare.net http://img146.imageshack.us/img146/2158/ricksadql2.jpg |
Thanks I will try and see if that works. I think after all is fixed i will put the stock pulleys back on. Wanna buy some used pulleys? LOL.....just jokes
definitely sounds like the reman alternator crapped out on you
Threads Similar to: Help!!!Serious Charge problems
| Turbo charge V6 | Alex McCartin | V6 Mustangs | 2 | November 11th, 2007 03:27 PM |
| charge motion plates | gtcs mustang 13 | 2005+ | 1 | October 15th, 2007 12:19 AM |
| Super charge or not? | mustangprincess00 | V6 Mustangs | 44 | September 1st, 2007 02:13 AM |
| Super charge or not? | mustangprincess00 | V6 Mustangs | 2 | August 31st, 2007 06:41 PM |
| Turbo Charge | dr.gonzo | 5.0 Mustangs | 2 | November 6th, 2006 04:22 PM |
