Fuel Pump getting 5 volts
Old August 9th, 2006, 09:06 AM   #1
OTreborO is on a distinguished road
I thought I had a fuel pump problem, but found out I am only getting 5-6 volts when I turn on the car or when I crank the engine. I checked the inertia switch, it is good, and also getting 5 volts there as well. Any ideas as to why I am only getting 5-6 volts???
Thanks,
Trebor
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old August 9th, 2006, 10:24 AM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
ck the relay.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 9th, 2006, 10:00 PM   #3
where
where is the relay? I thought it was under drivers seat, but found out that was an a/c relay
Old August 10th, 2006, 02:43 AM   #4
TENGRAM is on a distinguished road
Re: where
the one under the seat is the fuel pump relay. its identical to the a/c relay.
89 GT t5 3.73
www.my5oh.com/
Old August 10th, 2006, 03:14 AM   #5
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
on your 89???? If so I concur with what they said yank the seat out and check the voltage there.
TT Build in progress.......
Old August 10th, 2006, 09:18 AM   #6
OK, I did
I went to autozone and they looked up the part number and told me it was an A/C relay, then they showed me other relays for the fuel pump. One had too many prongs, the other had the correct amount of prongs but did not have the same shape as the Ford relay, the Ford relay had a bump/hump molded into one side, the replacement was square, but it should plug in.
I got 12V on one of the wires, I think it was Orange, and I got 6V on 2 of the wires, and I think 3-4 volts on the other wire.
ugh.............................................
Old August 11th, 2006, 02:15 PM   #7
Relay didn't fix the problem
Relay didn't fix the problem:
looks like 12V on orange wire and 4-6 volts on the other wires at all times
Any suggestions??????????????
Thanks in advance
BTW, The relay I got had an extra terminal on it, but I was told it was the replacement, apparently this one relay works on a lot of applications???
anybody have a good schematic of the fuel system electronics
One other side note, kind of funny, but hopefully not related is that when I turn on the right blinker the speedometer flashes
Seriously, the blinker works just fine, front and rear, but the light on the left side of the speedometer flashes instead of the blinker indicator LOL
Also the hazard flashers don't work, but that is probably because of the weird blinker
Old August 11th, 2006, 02:41 PM   #8
thats interesting cuz the f/p relay is behind the p/s kick panel by the computer
Old August 11th, 2006, 02:44 PM   #9
'89 with 4 cyl. had blk/org=12 volts at all times; red/blk switched power through inertia switch from ecc power relay; tan/lt grn to the eec; pink/blk to fuel pump
Old August 11th, 2006, 04:01 PM   #10
I was told the relay is under the drivers seat????????????
Oh my, I am so confused. I am ready to scream guys................
Some one please just kick me in the nuts
If I had 6 volts at the inertia switch would that mean the FP relay would not be the issue, maybe a ECC relay, not that I would know where that is located
Old August 11th, 2006, 06:56 PM   #11
according to my book...you had a blk/org from a fusible link--eec power relay---redwire to inertia sw.---red/blk to relay.
ok...red/blk at relay should have 12 vlts. blk/org at relay is fusible linked and should have 12 volts. the blk/org is the one going to the pump. Sounds like youre fusible links may have melted
Old August 11th, 2006, 06:57 PM   #12
see what you have at pin #1 of the ecc. its blk/org. comes off the fusible link side of the ecc pwr relay so it should have 12 vlts
Old August 11th, 2006, 07:15 PM   #13
Re: I was told the relay is under the drivers seat??????????
some models (4-cylinders i guess) had them in the kickpanel, but all of the ones i have seen are under the driverseat...i suppose because i've never bothered to look at a 4-pot :wink . if there is a relay under your seat, it is the FP Relay.
this diagram may help you with your problem - http://www.veryuseful.com/mustang/te...ng_Diagram.gif
89 GT t5 3.73
www.my5oh.com/
Old August 11th, 2006, 07:30 PM   #14
nice diagram...but his car is an 8 from 4 conversion, so hes looking at 4 cyl wiring which was different from the 8
Old August 11th, 2006, 11:32 PM   #15
this is where i become useless, as i have no experience with conversion wiring/methods...but i'll exit with this: it seems as though you are getting a VREF Signal (4-6vdc) rather than the VBATT (12vdc). i suspect the problem is FP wiring from the wrong ECM pin...but again, i know nothing about conversions good luck
89 GT t5 3.73
www.my5oh.com/
Old August 12th, 2006, 08:15 PM   #16
Voltages
I have 12V at pin 1 of ECC
Now relay at ECC:
Voltages with relay connected:
all 12V except black/green has 0V
Voltages with relay not connected:
Black/Orange 12V
Red 4 V
Orange/Black 4 V
Black/Green 0V
Red/Green 12V
Old August 12th, 2006, 11:10 PM   #17
ok...12 volts at pin 1 means fusible link is good.
blk/grn is your ground so it should read 0 vlts.
ok...blk/orange is fusible link, constant 12.
RED is 12 volts out of relay to inertia switch.
Orange/blk...?
Black/Green is ground for coil of the relay.
Red/Green is switched 12 vlts for the coil of the relay.
Now, you sure the Orange/blk isnt blk orange? The book shows
Blk/Orange off of the fusible link to the ecc relay. A second Blk/Orange comes off this terminal and goes to the ecc at pin 1. I say its all ok.
now go to the fuel pump relay and inertia switch....
the red coming off of the ecc relay goes to the inertia switch and then comes out as red/blk and goes to the coil side of fuel pump relay.
There is a blk/orange at the fuel pump relay which is constant 12 vlts.
Tan/Lt Grn at relay is the ground side of the relay coil and goes to the ecc on pin 22.
Pink/Blk is power going to fuel pump when relay is activated.
When you are for sure you found fuel pump relay, first turn key on and plug relay in enough to make contact and then release and see if it clicks. if it does...power to pump is problem. if not relay is bad or then need to ck power there.
Old August 13th, 2006, 06:46 PM   #18
latest on wiring
Relay is under seat because pink wire from fuel pump goes to this relay:
Here is what I found with relay unplugged:
Pink wire going to fuel pump has 5 V, weird???
Orange Blue has 12V
Tan/Green has 6V
Red/black has 3V
I got a new relay, but it still doesn't work
The relay I got has 5 terminals, the original has 4, Autozone guy said that was ok......
Any help appreciated
Old August 13th, 2006, 09:56 PM   #19
okay...go back to inertia switch, wire going in is red...has 12v? it should with key on. your red/blk at inertia switch, should have 12v with key on. if not...switch is bad. if you do, and you only have the 3v at the relay...trace the wiring back to inertia switch...wire either shorting or more than likely, a connector behind one of the kickpanels is coroded.
Old August 13th, 2006, 10:26 PM   #20
inertia switch
Inertia switch is ok, ohms less than 5
6V at the inerta switch :-(
Threads Similar to: Fuel Pump getting 5 volts
Fuel Pump stanginit 99-04 5 September 6th, 2007 04:36 PM
Fuel pump kwill5 96-98 1 August 19th, 2007 07:18 PM
fuel pump musclepony 5.0 Mustangs 1 August 15th, 2007 02:15 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
