Replaced Clutch....Big Problems
I replaced the clutch last night. Everything went smooth going back together. Put the car back on the ground buttoned up a few things. Gave it a good overall check. THen it was time for the test drive. Car starts up in N but won't go in gear. WTF clutch pedal all the way to the floor and nothing. Turn car off put it in first gear try and start it and car tries to move forward. We adjusted the clutch cable three times. Made sure it self adjusted. Did we get a bad clutch. The one thing that looked worn and wasn't replaced was the ball for the fork. Ball thing that is attached to the bell. Any Idea's. Yes we took every thing back apart. Going to get a different clutch from the parts store. Maybe we got the wrong one. Don't know what to look for or do.
Any idea's
1989 mustang GT 5.0
13.64@101mph
what clutch did you get?
It was a stock replacement. I can't think of the name.....I'm at work can't go and look at the box. But it was brand new and not a rebuilt. Came with everything.....Box said made in spain. I remember that much
I think it could have been a Dynapak
1989 mustang GT 5.0
Sounds like the clutch isn't releasing. This could be due to the cable adjustment problems, improper assembly (did you put the clutch disk in the correct orientation), or a warped or bad pressure plate.
My guess is you made some mistake during the assembly. |
The disk can go on only one way. The flywheel goes on only one way also. I had the flywheel resurfaced. The pressure plate is new came with the kit. Only thing we can think of is the ball for the Fork. THe cable is attached to the fork the fork rest on this ball. The ball is wore. Anyone know what i'm talking about
1989 mustang GT 5.0
soon to be fox body
the clutch can go on 2 different ways. you probably put it on backwards. trust me i have done the same thing.
starting from scratch |
are you sure. I thought the end with all the spring goes on the inside. the flatter side on the outside away from the pressure plate
1989 mustang GT 5.0
soon to be fox body
on the clutch it will say fly wheel and then the other side. i have done it before and had the same symptons that you are having. it suck that you have to take it back out but thats it i am sure of it.
I am going to take a look at the disk as soon as I get home.
Is it printed on the disk or something?
1989 mustang GT 5.0
soon to be fox body
yea it should. however you are going to have to take it out to see it as you should know that. but thats besides the point. once you have flipped it you should have no other problems with it.
That won't be a problem the clutch kit is all sitting back in the box it came in.
Now if it would stop raining by the time I get home....
1989 mustang GT 5.0
soon to be fox body
lol thats always the problem about working outside. thats why its nice to work in a shop daily
Did you allign the clutch when you put it in? it should have came with a little rubber tool that could be the problem????
I Wanna Go Fast |
soon to be fox body
its not rubber its plastic but its got all the teeth that align with the input shaft
#15 | |
#16 | |
If that isn't the problem, it is likely that you didn't have the cable adjusted correctly. I doubt it is your ball stud, unless you knocked the fork off the stud while you were putting the trans back in. I usually put the cable back on the fork and put some (just a little) tension on the fork so that it holds the fork in place while I put the input shaft back in there. When everything is back in place the cable should have some tension (just a little) on it before you ever touch the petal. If the cable is loose you need to take up some slack (firewall adjuster works nice for this). |
#17 | ||
The trans slipped back on with no problem. Didn't have to use the bolts to pull it in. Also the flat end of the disk did go up against the flywheel. If the ball was wore badly it will change the geometry of the fork. We also bent the fork ball clip things cause it was sitting on the ball alittle loose and that snugged it up. We pulled up on the clutch pedal then pulled the cable out and attached. How or does it self adjust. When you push down on it. How exactly do you reset the clutch cable?
1989 mustang GT 5.0
1987 ford mustang gt
well see when shes done
it adjust by pulling the clutch pedal up,but i would suggest you inveest in an aftermarket one ''if you dont already have one'' with an adjustable quadrant and firewall adjuster
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
#19 | |
if your pedal is just limp, you have too much slack in the cable or it is not attached to the petal correctly. The cable should not have any slack in it when you get everything back together. Buy a firewall cable adjuster for like $20 and it will solve your cable adjustment problems....but make sure that is your problem first. |
I will take all this info and try and use it later. I will keep you guys informed of what happened.
I need my stang back up and running. I feel lost with out it. Thanks for all the replies.......Keep em coming if anyone else want's to give their suggestions
1989 mustang GT 5.0
Threads Similar to: Replaced Clutch....Big Problems
| clutch problems | wsy480 | Parts | 2 | June 4th, 2007 09:00 PM |
| clutch problems.. HELP ME PLEASE!!! | 92mustanglx | 5.0 Mustangs | 11 | May 28th, 2007 11:04 AM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 10:08 AM |
| clutch problems | DanishStallion | 99-04 | 9 | May 16th, 2007 12:18 AM |
| 87 Ford Mustang, Replaced clutch fork cable. were do i ajust | luner35 | 5.0 Mustangs | 5 | March 4th, 2007 02:23 AM |
