hose
Old October 17th, 2007, 03:59 PM   #1
1987 ford mustang gt
well see when shes done
hose
what size fuel line should i use on my 408 build??im thinking -8an and what does npt stand for ''example 3/8npt compared to 3/8''
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old October 17th, 2007, 06:25 PM   #2
ttt
Old October 17th, 2007, 09:09 PM   #3
nolife's Avatar
91GT, 88GT, 02GT
NPT (National pipe thread) is tapered threads and tapered sockets or ports, not like a regular old bolt or screw where the threads are straight. It gets harder to turn as you tighten the joint because of the shape. NTP joints usually requires a sealing compound or teflon tape. AN is straight threads but has a 37degree flare (the pipe end or socket is angled). This angled part forms the seal so it does not require a sealing compound.
Old October 17th, 2007, 09:10 PM   #4
Thank you for clarifying that for me
Threads Similar to: hose
What Hose Is This Stang187 V6 Mustangs 18 November 12th, 2007 05:47 PM
Lifting a car with a hose TurboLX The Clubhouse 1 October 22nd, 2007 07:52 PM
hose dragpipe General Tech 1 January 24th, 2007 07:58 PM
Ice in the Hose? jamesalroy V6 Mustangs 4 January 8th, 2007 07:46 AM
Return heater hose and inlet hose mu5t4ng 96-98 32 January 4th, 2007 11:19 PM
