bbk holley and edelbrock
Old October 17th, 2007, 07:59 PM   #1
cali 5.0 is on a distinguished road
im building a 331 srtoker engine. i orderd my 331 kit from chp, its the street fighter kit and i got the motor out of a 94 cobra and stripped it down already jus waiting on the kit so that i kan send the block along with a piston to the machine shop to get it cleaned and bored 30over, i orderd dished pistons with a 9:1 compreesion and can handle up to .650-.670 in. lift. i already have the holley sytemax 2 manifold and was wondering if that manifold will match up to edelbrock victor jr. heads and bbk long tube headers?
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old October 17th, 2007, 08:06 PM   #2
1987 ford mustang gt
well see when shes done
why do you want vic jr's there too big.I would suggest a head with an intake runner around 185cc's.
347, torn apart again.
Old October 17th, 2007, 08:07 PM   #3
Re: bbk holley and edelbrock
and lift dont mean anythimng get a custom grind.And do you plan on supercharging this motor??
Old October 17th, 2007, 08:13 PM   #4
yeh, i want about mabe 10pounds. supercharged.
i no that the lift doesn't mean anything and i will get a custom cam from comp i jus included tht so that i wont go over that high of a lift when i get that cam.
and i'm goin with the victors because they can punch out 500hp (potentionally)
Old October 17th, 2007, 08:15 PM   #5
you just reading shit!!you dont have t have victors to make 500 hp.and your putting all this in a stock block????bad idea!!!
Old October 17th, 2007, 08:16 PM   #6
you wont ever need that much lift!!!
Old October 17th, 2007, 08:18 PM   #7
lol... im not saying tht i will... call it quality insurance
Old October 17th, 2007, 08:21 PM   #8
what do you mean insurance your just going to make your motor a dog if you overcam it
Old October 17th, 2007, 08:24 PM   #9
im not goin to put a cam that big in it, im sure that the cam wont be anything near that. i mean insurance as in its their if in case i want it...
or change my set up and need it
Old October 17th, 2007, 08:26 PM   #10
i see what your saying but im still concerned about your stock block
Old October 17th, 2007, 08:28 PM   #11
yeh me to.... LMAO
Old October 17th, 2007, 08:29 PM   #12
i mean seriously it might hold at wot and it might not
Old October 17th, 2007, 08:31 PM   #13
yeh i no, but im goin to gradually work my way up to that. the supercharger wont come until later on, like after i replace the suspension and tighten up the chassis and all tht shit
Old October 17th, 2007, 08:36 PM   #14
you really dont need vic jr's
Old October 17th, 2007, 08:40 PM   #15
1990 hatchback lx
Twist it up is on a distinguished road
Send a message via Yahoo to Twist it up
edelbrock heads will be fine my friend, you going big now and adding on later right? is this a street car?
www.hsvracing.com
Old October 17th, 2007, 08:42 PM   #16
yea vic jrs are not suitable for his application the runners are too big.
Old October 17th, 2007, 08:58 PM   #17
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
forget the edelbrocks and get yourself a pair of trick flows
Old October 17th, 2007, 09:03 PM   #18
+ 1 great heads or afr 185's
Old October 20th, 2007, 02:17 AM   #19
yeh its gonna b a street car, i am gonna blow it later on.
Old October 21st, 2007, 12:39 AM   #20
13.64@101mph
^ ew!!!
but seriously jordans right, w/ that set-up and s/c that stock block will blow up..those heads are seriously way too big and a set of 185cc or so afr's or TFS TW heads would be a lot better..and as far as that cam, to be honest a custom grind one will prob be in 560-590 lift area!!! but then pistons will need to be flycut and you're valve springs up'd too!!!
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Threads Similar to: bbk holley and edelbrock
Holley carb help! JONJON 5.0 Mustangs 4 October 27th, 2007 10:54 PM
bbk and edelbrock cali 5.0 General Tech 0 October 14th, 2007 11:34 PM
holley carb 9teen65coupe Classic Mustangs 10 August 22nd, 2007 08:15 AM
holley intake cali 5.0 5.0 Mustangs 8 April 21st, 2007 12:54 AM
Holley or Trickflow Tony_90fox 5.0 Mustangs 14 November 2nd, 2006 01:15 PM
