Discussing BIG PROBLEM in the 5.0 Mustangs Forum. on my 87 fox i noticed that the rear was kinda twisting when just driving. ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
BIG PROBLEM
87 LX 5.0 3.73 GEARS AND A CUSTOM CLUSTER BUILT BY FLORIDA5.0. THIS IS THERE WEB SITE RPERFORMANCE.COM |
1986 Mustang GT
Location: FOUND BWAL! hes now giving hand jobs to all paser bys
You might still be able the buy them from ford its the mount that welds in place right. You will have to find someone to re weld the new one on
look into a stangbox which is a solution for tearing out upper control mounts and is much tougher.and while your in their you should reinforcing kit for the lowers
Speed kills drive an import and live forever. 1991 LX 5.0 H/B 1990 T-BIRD SC |
1986 Mustang GT
Nice double post :wink we will have to let that go
i can re-weld it. can i buy it from the dealer? or aftermarket and what is
stang box? sorry if that sounds stupid
you can buy the upper torque box repair kit that bolts through the floor. It is a huge huge pain in the ass, but it will most likely fix the problem.
Personally, I would just weld it back together if it isn't too torn up or rusted out. you can patch it back together with some decent thickness sheet metal and a good MIG welder. But make sure you do it with the control arm in place and the rear end where you want it, otherwise your geometry will be off. |
yea i know. where it broke is not where it mounts to the car it broke where it mounts to the control arm. so.....................idk
Like I said, piece it back together with decent thickness sheet metal.
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
would you think that maybe angle iron would work or do you think that would be to much strain
#11 | |
IT shouldn't take much to fix it. I"d start by tacking along the seam where it broke with a MIG to put it back to one piece. Then fill in the crack as much as possible and reinforce with some extra sheet metal. just use tin snips and cut a piece about the same shape and size as the bracket. Then tack the sheet metal in place and put some 1 inch seams around it. The only other thing I can think of is having someone fab a new bracket for you. |
well i really appericiate it man thankyou
Threads Similar to: BIG PROBLEM
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Has your car ever had a problem? | JASonic | The Clubhouse | 17 | September 19th, 2007 05:19 PM |
| big problem need help | 96gtponyred | 96-98 | 12 | August 22nd, 2007 01:36 AM |
| RIM Problem and Help | trueballerisme | 2005+ | 70 | August 21st, 2007 08:55 PM |
| TPS Problem? | 88Horseman | 5.0 Mustangs | 11 | November 13th, 2006 11:46 PM |
