Boost Missing Need Help
Old August 10th, 2006, 12:44 AM   #1
MattB is on a distinguished road
I have a '94 GT with a Vortech V-2, Edelbrock Performer heads, BBK Headers, Ford Racing F303 Cam. This was all done before I bought the car. However lately I have lost approx 4 lbs of boost. I've checked all vacum lines and gaskets. No issues. Where else should I check?[/b]
Old August 10th, 2006, 12:57 AM   #2
mdvaldosta's Avatar
11.47@120.58
Slipping belt. Look for belt dust around pulleys.
Old August 10th, 2006, 02:26 AM   #3
Forgot to mention but I've already checked that too. I have tried my other pully which was pushing 12psi of boost. It also has lost 4psi and now only pushing 8. I have also checked the bypass valve by plugging off all lines connected to it and everything worked normal with the same loss of boost.
Old August 13th, 2006, 10:31 AM   #4
Zak
Zak is on a distinguished road
I have a Kenne Bell Blowzilla, set to produce 8 pounds.. but I only see maximum of 6 on the boost gauge... this was a camshaft issue, it had a long overlap or a tighter lobe separation angle.. so most of the boost was lost during the scavenging process!! I could hear the backfire at the exhaust tip. I changed to Steeda #19 and problem solved.
Your case, I guess it's a slippery belt as mdvaladosta said, or worse: wear in the compressor vanes that cause internal leak.. but do you have a bypass valve? Did you check it?
Old August 13th, 2006, 06:57 PM   #5
stang fanatic's Avatar
stang fanatic is on a distinguished road
running a cooler...ck for cracks
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 13th, 2006, 07:04 PM   #6
stangliter04's Avatar
stangliter04 is on a distinguished road
are you running meth injection??? I ahd the same problem running my meth...
Silver 04 Cobra... with a Whipple
Threads Similar to: Boost Missing Need Help
97 V6 missing on cyl 4,5,and 6 a_calm_victim V6 Mustangs 10 July 5th, 2007 08:48 AM
Car Missing Out Bad bigbadtalontsi 5.0 Mustangs 7 March 28th, 2007 06:14 AM
Car Missing Out bigbadtalontsi 5.0 Mustangs 10 March 11th, 2007 05:47 PM
Turbo Boost vs Super Boost droppedbass87 General Tech 12 October 16th, 2006 10:56 AM
Boost missing I think I found the problem MattB 5.0 Mustangs 0 August 16th, 2006 07:20 PM
