heads for my coupe
Old October 18th, 2007, 04:28 PM   #1
e-legal motorsports is on a distinguished road
heads for my coupe
I have a 89 coupe with a 91 motor Im wonting to put a x cam in it should I buy a set of head and what kind or have mine redone thanks
Old October 18th, 2007, 04:31 PM   #2
soon to be fox body
BROKINARROW is on a distinguished road
i was thinking about just having my redone but what machine shop can you trust? ya know
starting from scratch
Old October 18th, 2007, 04:34 PM   #3
Re: heads for my coupe
I have a frind that has his on biz and says he can do it beter than aftermarket heads for $800
Old October 18th, 2007, 04:39 PM   #4
1987 ford mustang gt
well see when shes done
you friend is fucking stupd!!!you will never be able to port stock heads and make them flow better then aftermarket heads.And second off why would you put 800 bucks into a port job when you can buy a set of trick flow tw heads for a couple hundred bucks more
we need to know your exact combo
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old October 18th, 2007, 04:44 PM   #5
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
and you wouldnt really be able to change you combustion chamber with out buying aftermarket head....you can port and polish and change out valves and valve springs......they wont be alluminum though
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old October 18th, 2007, 04:44 PM   #6
the moters a 91 witha 76 mas air 70 throttle bodie intacks ported,190 fule pump 410 gears x pipe under drive pullys and a phenolic spcer kit still crank forged pistons
Threads Similar to: heads for my coupe
T-Top Coupe? bigchimi 5.0 Mustangs 16 February 15th, 2008 09:45 AM
68' Coupe tatumsilver Classic Mustangs 6 July 29th, 2007 08:23 AM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 09:55 PM
what should I do (67 coupe) cjcurtis65 Classic Mustangs 4 February 23rd, 2007 08:33 AM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 03:18 PM
