94-95 spindle swap on a 1990 Notch
Old October 19th, 2007, 01:11 PM   #1
kevnsue is on a distinguished road
I want to run a set of 2007 bullit wheels off of a new mustang. I have seen people running 05-07 wheels on fox's body cars. How are they doing it without rubbing (Spacers)? And if that is how they are doing it is it safe and where do you get them and what size and (Thick) and do you have to change the studs to do it. Any info would be greatly used. Thanks
Old October 19th, 2007, 04:39 PM   #2
ryans88gt's Avatar
I think if you get a set of thick 4 lug to 5 lug conversion spacers, you'll kill 2 birds with one stone. It will give you the right back spacing (approx) and give you 5 lugs.
http://cgi.ebay.com/ebaymotors/RARE-...spagenameZWDVW
I wouldn't go autocrossing with them or anything, but you should be fine on the street.
Old October 19th, 2007, 06:55 PM   #3
The Razor's Edge
White Thunder's Avatar
how safe are those for alot of power?
founder of the FTN Club
Old October 19th, 2007, 07:44 PM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
the lug pattern is diffrent between 05-up and 94-04
Old October 20th, 2007, 09:51 AM   #5
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
They are the same as the spacers posted above. Most Mustangs are 5 on 4.5.
ΜΟΛΩΝ ΛΑΒΕ
Old October 20th, 2007, 06:37 PM   #6
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
they are they samebolt pattern i sold my set of my 95 spindles and my dad put them on his 05 v6 no problem i have sn 95 spindles and my wheels clear fine no rubing 17x9
Old October 20th, 2007, 07:12 PM   #7
1990 hatchback lx
Twist it up is on a distinguished road
Send a message via Yahoo to Twist it up
so sn95 spindles will fit a fox body ??????? i got a 95 convertable parts car
www.hsvracing.com
Old October 20th, 2007, 07:17 PM   #8
86ttops's Avatar
n/a
yes you need to use 95 ball joints oe use washers because the threads dont go down far enough to tighten up but other then that yes you have to use the brakes as well
Old October 20th, 2007, 07:20 PM   #9
86ttops's Avatar
n/a
the rear axles will not work unless you roll your fender lip they are 3/4 inch wider but yoy can use the ranger or areosta van axles 95 brakes but cut the caliper braket so it fits over the axle and bolts to the inside instead of the out side or buy some for $200
Old October 20th, 2007, 07:29 PM   #10
1990 hatchback lx
what about the tierod hookups?
www.hsvracing.com
Old October 21st, 2007, 12:55 AM   #11
86ttops's Avatar
n/a
Fit right up you have to unthread them a bit and have it allined
Old October 21st, 2007, 08:50 AM   #12
1990 hatchback lx
you talkin about the whole rear end or just the axle shafts??
www.hsvracing.com
Old October 21st, 2007, 12:40 PM   #13
86ttops's Avatar
n/a
provided you have a 8.8 you can get axles shaft here is a site with all the info i used stock 94-95 caliper mounting brackets and cut them and fliped them to the inside of the axles i can get some pics if you need them this swap will end up costing you $600 to $800 if you buy every thing but the axles new
To keep the stock rear wheel offset and drums, the '83-'92 Ranger/Bronco II Left (driver) side axle (29-5/32") from a 4cyl or 3.0L V-6 with the 7.5" rear end, or '86-'97 Aerostar RIGHT side axles (29-5/32") is what you want. They are the same rear axles, the center section is just on the opposite side when you compare the rear ends. The pumpkins are also off center unlike the Mustangs, so you will have to find two vehicles to pull axles from! You will need the drums from either of these vehicles also if you are staying with rear 9" drums. The 7.5 axle Rangers & Aerostars use 9" drums. These parts are direct 5 lug replacements for the stock 9" rear drums on the 79-93 Mustangs.
hope this help anyother questions or need pics let me know
http://mjbobbitt.home.comcast.net/~m...tang/5lug.html
Threads Similar to: 94-95 spindle swap on a 1990 Notch
Front spindle torq spec. Katen Classic Mustangs 1 September 19th, 2007 08:26 AM
wheel spindle removal smoke-em 99-04 3 May 31st, 2007 09:08 PM
1990 5.0 LX vs. 1990 GT Ga_50_foxbody 5.0 Mustangs 8 January 16th, 2007 12:16 PM
Rear seat swap 1990 to 1989 OTreborO General Tech 0 April 24th, 2006 12:43 PM
