2002 gt supercharged
Rear Control Arms Subframe Connectors HELP!!! TOO CHEAP??
I found this on ebay and i am getting an exhaust on my dad
and he says i can also get this if they are any good ??Also are ford racing or summit springs any good? LINK |
Big timin' in a small town
Those arent bad worth a try the Subframes look flimsy as shit though.
With blueovalindustries, you can typically get a better overall price when buying directly from their web site and not through ebay.
Those sub frame connectors do look a little weak. I don't have ones with seat supports and I think they may be home made but they are very heavy and very thick. Don't pay attention to the black and gray paint, I am actually in the middle of re doing the entire underneath of the car.
how thick is the stock subframe? and did you media blast before you started to paint the under body and what paint are you using? Thanks for the help guys!
Good point. The connectors you asked about from blueoval are 14 gauge which is probably at least equal to many parts of the existing sub frame and the seat connecter will provide support as well.
The underneath? Sanding and many wire brushes. The underneath overall was not bad, there were a few spots worse then others but over 90% of the body underneath was still covered in good paint and the other 10% were spots of surface rust with only one single spot of concern. Since it was already in decent shape, I am doing nothing elaborate, just taking my time with primer and using several coats of rattle can gloss black (suspension) and/or rubberized undercoating (body). I've done a lot more since those pics were taken. I'll be done by spring
I made mine out of 2x2x 1/4 box kinda heavy but low so good place to add it and with the t tops i didnt want to have to think about it again they are nice i jack the car up buy them all the time with seat supports and i have a set of jack rails off a vert i was thinking about using might sell them though
Well i am going to make my own at least try
![]() But i was wondering if i should make a bracket that came down like in the pick or weld it to the side of the subframe with a piece of heavy steel over it to stiffin it up i am more then open to any thoughts!! I think i will be using 2x2 and box it in and i was thinking 1/8in thick?? THANKS for all the help
i like nolife's subframe conectors, and im doin the same thing painting underneath my stang right now... looks good
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
I like my subframe connectors the best out of any other brand I have seen so far. They are Competition Enginerring and i recomend them to everyone thinking of putting on subframes. They fall right in place and they are very good. I can link you to them if you like they only cost $130 too
#10 | |
1987 ford mustang gt
well see when shes done
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
I do I love them. And guys my buddy Jordan told me about them after I asked on here the best ones when I had it narrowed down to three.
#12 | |
Sorry i forgot to say i was going to fit the contour of the floor pan. i was thinking i could weld it too the floor and of corse take out the seats and carpet. also i am in no hurry and already have the steel but if you dont think this will work i want to hear it! and also know why you think or know it wont.
Note: that i have not been able to look at the underside of my car because it is in storage for a few more days until i get my DL back so sorry if this sounds really dumb.
Threads Similar to: Rear Control Arms Subframe Connectors HELP!!! TOO CHEAP??
| Anyone use the BBK Gripp Rear Control Arms? | Speedstang302 | 5.0 Mustangs | 22 | October 19th, 2007 09:28 AM |
| rear control arms | bullitt1238 | General Tech | 11 | October 18th, 2007 01:35 PM |
| Rear upper and lower control arms | neckbonekat | 99-04 | 8 | August 19th, 2007 02:28 PM |
| upper / lower rear control arms | Invictus | 99-04 | 2 | December 29th, 2006 07:06 PM |
| upper / lower rear control arms | Invictus | Modular Mustangs | 8 | December 27th, 2006 11:33 AM |
