Building Engine
Old October 20th, 2007, 04:11 AM   #1
1998 Mustang GT
Need to hit the track
RandoGT is on a distinguished road
Building Engine
alright so i'm just curious, what all are the parts needed to build a good engine. let's just say one buys a short block, what all else does he need?
also, around how much would all that cost? well, a pretty good dealing HP engine. past 300HP N/A
Old October 21st, 2007, 09:06 AM   #2
dapack69 is on a distinguished road
Send a message via AIM to dapack69
Cost depends on what parts you use and who builds it.
Do you plan on going with a power adder down the road?
Custom engine built from Super Six, Cam from Delk performance, Custom Novi 2000 in the works.
My Car
www.supersixmotorsports.com
www.bc-automotive.com/
Old October 21st, 2007, 11:10 AM   #3
1998 Mustang GT
let's just say we keep it N/A. i'm not planning on building an engine right now. i'm just saying to assume
Old October 21st, 2007, 12:24 PM   #4
Then how many RPM's are you going want to run? You building a street car, drag or autocross?
My Car
Old October 21st, 2007, 05:40 PM   #5
1998 Mustang GT
Street/Strip
Old October 21st, 2007, 09:16 PM   #6
AM1AW is on a distinguished road
There is no real answer for you since your just curious.
If you want a street/strip engine. First you need to know your budget.
It might be more cost effective to just buy a long block that is already built and ready to install if you are going to have to pay somebody to build it for you.
Or you could just start off by buying the block itself. decide if you want to build a stroker or regular engine. going this route you will need EVERYTHING from the crankshaft, pistons and rods, heads, intake, front engine parts like water pump, alternator, pulleys, and a flywheel. plus all the other stuff.
Most people buy a short block when they already have an engine so that they can use a lot of the existing parts.
If you were to just buy a short block it depends where you get it from, some sell the short block with heads already installed, some don't.
There are just way to many variables involved to list all the things with price ranges and reach a HP goal.
Old October 22nd, 2007, 01:49 AM   #7
1998 Mustang GT
well that helps out. (not being sarcastic) i'll have to sit down one of these days and look into what i want
Old October 27th, 2007, 04:56 PM   #8
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
You start by planning your build spend as much time comparing products and how well they work togather. Thaen you enginer your build and start the build. The key to cost control in research, planning your build; than build your plan. look at 10k to 15k to get into the 12s
Old October 29th, 2007, 10:57 AM   #9
13.64@101mph
i got into 12's w/ about $5 including cost of car..($2400)
you can call up coast high performance and talk to them bout building you an 302 stroker or 351w stroker, i suggest an 347ci stroker..they can build you a complete balanced 347 shortblock for about $2200..then look into the trickflow top end kit and that w/ have everything you need, except the supporting mods like TB, MAF, injectors, AFPR, fuel pump, UDP, and full exhuast, that kits about $2500..and w/ that you should be around 425hp to the crank..tuned, maybe a little more..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Threads Similar to: Building Engine
Building a 306??? JONJON 5.0 Mustangs 57 October 22nd, 2007 09:47 PM
building mustangs seat cover company New Members Introductions 4 March 4th, 2007 02:12 AM
Engine building tech Q Zak 5.0 Mustangs 1 August 27th, 2006 06:41 PM
Need help with building a 347 !!!! 91stan 5.0 Mustangs 23 May 10th, 2006 09:01 PM
engine building tools 99mustang232 The Clubhouse 3 January 26th, 2006 01:20 AM
