Leaking crank seal and choppy front tires?
I think my tech is trying to bs me into getting new tires. He rated my front as 9's and the back as 7's. I just bought a front one a year ago and listed the front ones as choppy. What does this mean?
What is a crank seal and what happens when they leak? How major is this? Thanks
1994 Mustang Gt convertible Cobra R rims Bassani X pipe & flow masters Upgraded Sterio System |
1990 GT
i dont know what he meant about the tires, but the crank seal is easy to replace. it will leak a little oil and just get worse over time.
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
choppy is from no rotating you tire the tread start wearing un even and get chopy and then they start making more noise and can slip a belt or blow eventaly have you rotated them and how many mile are on them?
The Razor's Edge
9's on the front and 7's in the rear
#5 | |
1987 ford mustang gt
well see when shes done
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
#6 | |
48.47@ 12.58
he knows!!he being a goof!
the inside edges are probably "feathered " from not being able to rotate from front to rear, if they're not directional swap from left to right if you worried about the wear
www.hsvracing.com |
Threads Similar to: Leaking crank seal and choppy front tires?
| 5.0 front main seal | lugthug713 | 5.0 Mustangs | 1 | August 23rd, 2007 09:38 AM |
| Leaking output shaft seal. | gotboost562 | 5.0 Mustangs | 1 | August 12th, 2007 04:30 AM |
| Car leaking water front drivers side | Timmano | V6 Mustangs | 5 | May 23rd, 2007 01:39 PM |
| front tires, what do you run? | SWEET2KSTANG | Drag | 1 | April 9th, 2007 09:10 AM |
| T5 rear seal still leaking after install | 83 5.0 | 5.0 Mustangs | 6 | January 8th, 2007 09:17 PM |
