Cooling problems
I have a 93 mustang gt with a 347 stroker (r302 block) and a paxton novi 2000 putting out about 14psi. my problem is the cooling.. I have a griffin radiator with a 16" flex lite fan and an edelbrock high volume waterpump... It has a 160 temp thermostat and 50/50 water and antifreeze with water wetter added.. the car on the streets goes up to 200-210 degrees.. That canr be good with aluminum heads right ? Is this a hotter runin engine and thats the temp it should be or is there something i can do to lower the temp on it...
p.s. its been tunes so its not to rich or lean.. Thanks Ron |
One Man Wolf Pack
Welcome to the site.
I can't help ya with your problem but it sure sounds like a hell of a car.
![]() ΜΟΛΩΝ ΛΑΒΕ
When did the problem start after what mod it is possible to have to fast of a water pump if your runing under drive pullys and high out put pump it move to fast throught the radiator and doesnt have a chance to cool how many cfm is that fan is there a shroud? with a 16 fan you need a shroud or run two smaller fan two fans and a shroud is the best make sur your stat isnt bad as well how many core is your radiator i take it it is aluminum?
i put the whole setup in at one time, its all new... i dont have underdrive pulleys, the fan is a 2800 cfm unit by flex lite and it has a shroud.. i have an aluminum 2 core radiator and i changed the stat twice...
see why im puzzled Ron |
#5 | |
Re: Cooling problems
After idiling for a bit it does go up, and it goes up even driving down the road..no the flap is not there....
Suburban_concepts |
#7 | |
You need that flap or the car will run hot. That flap directs air up toward the radiator. Without it the radiator doesn't see much airflow.
Were does that flap actually hook up... do you have a pic...
Suburban_concepts |
is the lil piece under the lower bumper on darrle's car that's it.....another thing going to a tad hotter stat will help the rad to have a little more time to cool....what is your timing? are you also using a factory hood?
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
#10 | |
Threads Similar to: Cooling problems
| cooling problems | RyanGT | 99-04 | 30 | August 16th, 2007 08:42 PM |
| Cooling Fan | Stangzilla | 5.0 Mustangs | 23 | March 25th, 2007 11:15 AM |
| Radiator Cooling Fan Problems | jagstang96 | 96-98 | 1 | October 15th, 2006 06:05 PM |
| Cooling Fan Problems | rene9 | 96-98 | 6 | September 26th, 2006 07:29 PM |
