92 gt 5.0 engine will not turn off
Probably a bad ignition switch. Pull the batter cables off.
thanks for the reply
allready changed it out as well as replaced selenoid
Big timin' in a small town
Rip every wire out that runs to the engine its bound to turn off
maybe starter is bad?
#6 | |
Re: maybe starter is bad?
kind of hard to tell, she does not sound right
the selenoid that i replaced was the fire wall not battery
the selenoid that i replace was the fire wall not the battery
#9 | |
Re: the selenoid that i replaced was the fire wall not batte
You need to find out why. Test the small wire that connects to the solenoid. Is it hot contstantly or just when the key is turned to start?
my 90 lx had a recall on the ignition switch, i think that was the problem for the recall....
www.hsvracing.com |
do you have an electric fan or anything like that?
found out the problem, ground wire on starter
#14 | |
#15 | |
all motor
92 coupe
9.94@136.40
#16 | ||
I just read an article about the dangers of drinking ... And it scared the crap out of me. So that's it............... After today, NO MORE READING. |
#17 | ||
13.64@101mph
#18 | |
#19 | |
#20 | ||
all motor
92 coupe
9.94@136.40
Threads Similar to: 92 gt 5.0 engine will not turn off
| Mustang wouldn't turn over. | Kevin | 99-04 | 21 | August 26th, 2007 01:33 PM |
| Turn Signal | Youngin | The Clubhouse | 11 | August 18th, 2007 09:20 PM |
| turn on without key | notsoslow50 | 5.0 Mustangs | 17 | August 3rd, 2007 09:59 AM |
| turn signal? | thatonekidw/theGT | Modular Mustangs | 3 | July 22nd, 2007 05:39 PM |
| Key Turn Issue! Please Help | yellowstang98 | Modular Mustangs | 5 | May 9th, 2007 10:58 AM |
