1988 Ford Mustang GT
8.372@82.8 1/8mile w/1.825 60'
Building a 306???
I am still guessing what I want to build I was thinking of a 306 because it is going to be a street car and I like to make as much HP out of small engines as I can.I want to know what you guys are building and have had success with.Thanks
just build a 347 its very streetable and a little beter than a 306
+5 on the 347, and put a turbo on top of that, its streetable with boost control and they are EXTREMLEY badass, go with like a 76mm, that should put you in the perfect efficiancy range of the turbo and be making around 500-550, but then you looking at a new block, so on second thought, if you want the stock block maybe go with like a 67, and make around 450 and then if you were to get a new block you could still crank it up a little more
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#4 | |
Big timin' in a small town
331 works too!!!! 347's smoke after awhile when daily drivin.... just my opinion...... a little spray takes care of the smoke machine!!!! :award
www.hsvracing.com |
#6 | |
fabricated???
everybody knows a 347 is a smoke machine and won't last as long as a 331.... i didn't say mine smoked, just the redneck racers at the track, i know there's those low ring pistons that prevent smokin but they're prone to failure right? you pretty smart darrell but they do smoke after daily driving.... lots of power and high reving mofo!!! you never seen one smoke darrell????
www.hsvracing.com |
i havent
1989 LX Coupe
There is no reason a 347 would smoke or burn more oil than any other motor if it's built right. The piston pin/ring issue has been taken care of by alot of manufacturers like Probe.
#10 | |
1987 ford mustang gt
well see when shes done
coming in here calling it a smoke machine they were not a smoke machine you have a very wrong idea ytes they smoked some but were not smolke mahines b/c they smoked alittle.Almost everybody has solved this oil ring issue with a shorter rod or the piston manufacter has moved the oil ring farther up on the piston.Quit giving everybody the wrong idea about stuff if you have never had one.and why do you say everybody knows a 347 is a smoke machine
#11 | |
#12 | ||
bring your 347 and i'll hand you your ass with a 306 .....
www.hsvracing.com |
#13 | |||
mmm highly doubtful |
#14 | ||||
10 sec. fox bodies come a dime a dozen my friend, the fastest time slip on the site has me by a second but i'm runnin a 306 on a 150 shot.... all about hookin up my friend :award
www.hsvracing.com |
damn thats nice I want to be there with my 306.I am really leaning towards a 306 from the beginning.
#16 | |
1989 LX Coupe
Exactly... |
#17 | |||||
with a 425 with heads and a bigass carburator, does darrell spray his wheelie machine?
www.hsvracing.com |
nope he had it one there where he could negotiate lengths when he raced but he never sprayed the motor
The Razor's Edge
why argue with people that are here with the same cars and same goal.....fuckin relax with your 306 and i'll build a 347
Threads Similar to: Building a 306???
| building a 1985 gt | FastBack71 | 5.0 Mustangs | 21 | March 8th, 2007 10:31 PM |
| building mustangs | seat cover company | New Members Introductions | 4 | March 4th, 2007 02:12 AM |
| Building the rear.... | stangliter04 | 99-04 | 1 | February 28th, 2007 01:07 PM |
| Need help with building a 347 !!!! | 91stan | 5.0 Mustangs | 23 | May 10th, 2006 09:01 PM |
| Building a motor | DirtyMach1 | The Clubhouse | 22 | November 16th, 2005 03:34 PM |
